Big Ten With Disc
4 replies to this topic
#1 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted June 04, 2013 - 01:48 PM
Pulled the big ten out today and hooked the disc up, broke up the ground for some new grass and all in all it do really good!
  • Alc, Texas Deere and Horse, hamman and 1 other said thanks
  • 14,889 Thanks
  • 15,514 posts
Posted June 04, 2013 - 02:07 PM
Glad to see you had a good set of insulated pliers handy.Animated%20Gif%20Lightning%20%2812%29.GI
#3 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted June 09, 2013 - 04:36 PM
I guess you don't know that all you have to do is take the priers or even a screwdriver and ground the tip of the plug to the head of the engine to stop the engine. It is not necessary to remove the plug wire. Early engines just had a spring lever that the spark plug held in place and to stop the engine you simply pressed it over against the tip of the plug. No need for anything insulated as long as you didn't tough the tip of the plug with your hand before the spring lever.
Also a safety issue: if you are going to pull that disc off the lift lever, which is improper, you need to run an arrester chain from the disc down to the draw bar to prevent the tractor from turning over backwards onto the disc should you happen to hook it on a big root or a gate post or something. Standard safety practice is to pull nothing from a hitch point above the axle.
Edited by skunkhome, June 09, 2013 - 04:45 PM.
#4 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted June 10, 2013 - 06:53 PM
@ skunkhome thanks for your input, but first off I can't use the grounder on the spark plug because safety tip: you should have wire covers on your spark plug. The big tens and almost everything after the b1 didn't use the grounding out system to stop the engine, they had keys. Also my disc is light weight and securely fastened, I've been using it like this for a while now and have never had a problem. Thanks for your concern.
#5 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted June 13, 2013 - 12:46 AM
I guess my suggesting that "high hitching" is unsafe is a moot point when you are riding on the disc. But I am relieved to know that you have a sparkplug boot. :D
