1969 Ss12
17 replies to this topic
#1 willy OFFLINE
willy
  • 73 Thanks
  • 86 posts
Posted June 04, 2013 - 12:23 AM
    Was given a model # 917-25510 today , trouble finding real Tecumseh # . Sears 143-602022 . Have not had time to check motor ( ran 11 yrs ago, love that line ) , but it was free . also a disk for it . Not to bad of shape , some one painted it black but not the hood or chrome . Missing cig lighter so it's only worth 1200, HA ,HA
  • MH81 and hamman have said thanks
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted June 04, 2013 - 01:09 AM
:picsoritsnotyours:
  • hamman and 1978murray have said thanks
#3 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted June 04, 2013 - 07:38 AM
:ditto:
#4 Lmiller3358 OFFLINE
Lmiller3358
  • 1,478 Thanks
  • 1,417 posts
I  have a 68 ss12, had the same tech motor # issue also,, I think I did run the model # on the Sears web site, of coarse the motor is no longer available, then I think I went to Parts Tree from there .
#5 willy OFFLINE
willy
  • 73 Thanks
  • 86 posts
Posted June 05, 2013 - 01:37 PM
  Found a round tuit . Hooked a battery up gave it a spin . Starter/Gen works good , but no spark . There is a wire that comes out from behind flywheel that is mounted to air shroud , then another one from mount to nowhere . Does the nowhere wire go to the switch ? In the wire diagram shows a fuse? or something on this run back to the switch . Does it need to be hooked up for spark ?  I blew out the shroud , but maybe something ( spider web or mice ) is blocking trigger .
#6 TAHOE OFFLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted June 05, 2013 - 01:49 PM
You probably have an early CDI/SSI module system on that one. They are usually a grounded system when you turn switch off. I would pull shroud and take a pic for us. Do not connect any of those wire to 12V+, you will burn up the ignition which is expensive.
go to this website,
 http://www.searstractormanuals.com/
down left side click on "sears tractor" then go to next drop down box and scroll down to the 68 SS12 "parts list" manual. Once it loads, you can down load and save to your computer, the 69 manual doesn't have a wiring diagram, should be similar to the 68 though.
Edited by TAHOE, June 05, 2013 - 01:50 PM.
#7 MH81 OFFLINE
Posted June 05, 2013 - 02:32 PM
There is a list of diagrams here
http://gardentractor...iring-diagrams/
#8 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted June 05, 2013 - 08:32 PM
I just went through the same problem.  The phantom wire goes back to the ign switch.  When you turn the ign switch off, it grounds that wire. So just the opposite.  Try disconnecting the phantom wire and see if you have spark.  If not, try this site, it has good info on trouble shooting your iggy.   http://home.earthlin...oller/id11.html
H
#9 willy OFFLINE
willy
  • 73 Thanks
  • 86 posts
Posted June 05, 2013 - 09:25 PM
      Thanks     Leaving town going to the farm , guess it will still be here when I get back . Unless the tractor cures itself , it may need time alone
        Willy :toilethead:
#10 willy OFFLINE
willy
  • 73 Thanks
  • 86 posts
Posted June 10, 2013 - 02:31 PM
    Hi was just wondering would a HH180 fit ? Or does it need mod's
#11 willy OFFLINE
willy
  • 73 Thanks
  • 86 posts
Posted June 10, 2013 - 02:45 PM
   Doe   It's a OH 180 , its on a Dayton Gen. Free needs carb. the bolt that holds the bowl falls out . Maybe parts for the HH 12 , or fix and sell ?
#12 MH81 OFFLINE
Posted June 10, 2013 - 03:49 PM
I think the oh would fit... With a few mods to the tractor.
I think the hood needs raised a scosh and the wiring would need some attention.
#13 TAHOE OFFLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted June 10, 2013 - 04:23 PM
The HH120 is a flathead, the OH180 is overhead valve, not going to be a whole lot that will interchange.
The 18 will fit, but will be tight, the front grill may need spaced up and the support bar that goes across top will need to be bent or removed as it will sit right across the rocker box.
Make sure you check the 18 crank, many of the generators used tapered shafts/pulleys, the 12's will not just slide on.
#14 willy OFFLINE
willy
  • 73 Thanks
  • 86 posts
Posted June 21, 2013 - 05:45 PM
     Hello All
Made it back ,but have been working on a Gibson SD , & a early Economy ( tiller steer ) 23 fb motor .  Got some time today to work on the SS12 . Pulled the flywheel (13021 ) well someone has been in here before no key , the wire to the coil was pulled apart . There is still a pcs of wire on the coil side . I am going to add to it and check it out or is there a way to check the coil ? Also need to know size of key don't want to buy a hand full . Coil # 7190 , 8 ,6 hard to tell last # .
        Yes I know pic's working on it
        Willy
#15 MH81 OFFLINE
Posted June 21, 2013 - 06:41 PM
It might be best to take a Pic of what is there so the guys have a visual. Glad you got the free time to work on her.
