Broke My Mf12G
21 replies to this topic
#16 CADplans OFFLINE
CADplans
  • 219 Thanks
  • 213 posts
Posted June 04, 2013 - 10:49 PM
I, on the other hand could roll start a hydro!!
:bigrofl:
  • MFDAC said thank you
#17 MFDAC OFFLINE
MFDAC
  • 3700 Thanks
  • 1769 posts
Posted June 05, 2013 - 06:05 PM
With hills like that it could probably be done!-LOL
#18 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted June 05, 2013 - 06:25 PM
Thanks MFDAC.
Now I remember.
I recognize the hydraulic pump/valve set up.
Glad to see it's still doing it's job.
#19 SearsYellow OFFLINE
SearsYellow
    Mower Extraordinaire
  • 514 Thanks
  • 599 posts
Posted June 05, 2013 - 06:48 PM
Sorry man i didn't get by the Post Office today I got tied up buying chemicals for the grapes today. It's grape growing season and I have not even sprayed the first time this year.
I figured it was time to get my rear in gear.
Edited by SearsYellow, June 05, 2013 - 06:51 PM.
#20 MFDAC OFFLINE
MFDAC
  • 3700 Thanks
  • 1769 posts
Posted June 05, 2013 - 08:48 PM
Thanks MFDAC.
Now I remember.
I wish that it still had the original engine but that is long gone. That's a 10 HP Tecumseh on it now, after I tired out a B/S 8 horse about 5 years ago. Been using it for dirt and snow work for a couple decades. Never knew anyone liked them 'till mid 2011 when I found this site!
You gotta take care of business first! Whenever you can get to it is ok, the old Murray will get it done till then. It sure looks like exactly what I need! Thanks again!
Later---DAC
#21 MFDAC OFFLINE
MFDAC
  • 3700 Thanks
  • 1769 posts
Posted June 17, 2013 - 10:07 PM
Here is an update. I got the starter from Sears Yellow today,and his suspicions were right that the starter he had may have been overheated. The outer windings had fried wires and some armature plates had been hit with some debris causing them to spin on the shaft slightly. This gamble was looking like it probably wasn't going to pay off but I decided to put an ohm meter to the armature commutator poles and every pole read zero ohms, even with the obvious damage to it, meaning no wires are broken in it! I went ahead and polished the commutator and installed it in my housing and it works great!
Now I have to figure out why the cutting deck seems to be dragging the engine down bad enough to make it stall. Maybe the engine is too tired and can't pull it anymore so I better start looking at a rebuild too.
Thanks for all the help from everyone especially Steve--SearsYellow!
Later---DAC
#22 SearsYellow OFFLINE
SearsYellow
  • 514 Thanks
  • 599 posts
Posted June 18, 2013 - 07:30 AM
I'm glad it worked out for you!! Anytime. I should have sent you all the Massey Ferguson parts I had also. I didn't think about it till after I shipped the starter. Basically some tank bands and some pulley guards for the engine.
