Looking really nice!
My Recent Freebee
#61
OFFLINE
Posted July 09, 2013 - 03:26 PM
- js5020 said thank you
#62
ONLINE
Posted July 09, 2013 - 04:02 PM
On the axle with bad woodruff slot, if you could fab up a copy of the key in brass, then you could simply lay it in the damaged keyway slot, then weld the axle & direct the molten weld up against the key. The brass won't fuse and the weld runs right up against it, leaving a pretty good repair. Then once finished, remove the key and carefully use an angle grinder to grind the weld down till it's all good & round again. I did this on my 1st John Deere F935 with straight keys, and it did super.
- js5020, twostep and LilysDad have said thanks
#63
OFFLINE
Posted July 10, 2013 - 07:58 AM
Nice machine you have there, sweet engine upgrade! What size tires is that machine sporting? I was thinking of the same configuration on the tires as this will likely never get a mower deck on it.
The rears are 23x8.50-12 Deestone AG's. The fronts are 4.00-8 Deestone Tri-Ribs. Thanks
Matt
#64
OFFLINE
Posted July 10, 2013 - 07:48 PM
Todays project was to do something with that keyway in the rear axle,,,, well I ended up doing a combination of suggestions,, I ended up welding one side of the keyway using a brass blank I made up and then since the other side was worn but not bad enough to get the welder in there I used a pric punch to deform the metal to close things up on both sides, ground things up nice and smooth then put a flat spot where the 2nd locking screw makes contact with the axle,,,, lets see it tear that up!! While I was at it I managed to get the other hub off and put a flat on that axle also,, hopefully it should be good for another 40yrs? Maybe tomorrow I will get the trans all painted up and ready to bolt to the frame,, thats IF I can get the danged freewheel screw to break loose, Grrrr pita thing been spraying juice on it since I got the thing and still stuck fast,, tomorrow it may get the hot wrench, done playing with it!
#65
OFFLINE
Posted July 10, 2013 - 11:27 PM
Looks great....
#66
ONLINE
Posted July 11, 2013 - 06:31 AM
"Hot wrench" may affect O-rings. Dunno'
- Team_Green said thank you
#67
OFFLINE
Posted July 11, 2013 - 09:06 AM
MUHAHA I musta scared it mentioning hot wrench,,, it finally gave in and I was able to break it loose,,,, trans is all painted, once its dry I'll get it secured to the frame.
#68
OFFLINE
Posted July 12, 2013 - 07:58 AM
Transmission is back on the frame and all hooked up,, next week I better get moving on rims, tires and the engine. Currently chasing down what looks like a nice later model 42" single stage blower and blade,,,,, Unless I run into something terrible Im gonna have less into this thing fully equipped (snowplow, snowblower, weights, chains, moldboard plow, and disk) than buying a blower and weights, chains for the X300R, heck I might even be under the price for a new 48" blade and weights!
#69
OFFLINE
Posted July 12, 2013 - 02:16 PM
Update on the blower and blade,,,,, OMG wait till ya all see the pics of these gems! They were so good I had to bring em both home! Eye candy to follow.....
#70
OFFLINE
Posted July 12, 2013 - 04:54 PM
Ok pic time,,,,
[/URL]">http://
[/URL]">http://
[/URL]">http://
[/URL]">http://
The previous owners son said they bought the blade and blower new and only used the blower twice, it shows as the paint is still on the auger, and inside the chute, it was also kept inside, its good as new, the blade even has the WH sticker still on the front edge,more dirty than used but not as close to new as the blower, they also had as close to a NOS WH sweeper as you will find.
- olcowhand, twostep and LilysDad have said thanks
#71
OFFLINE
Posted July 12, 2013 - 05:43 PM
Go buy the sweeper.. then sell it.. serious.. BTW.. NICE score.. i guess this means more time for your tractor as the attachments need nothing..
#72
OFFLINE
Posted July 12, 2013 - 09:30 PM
wow. that stuff is as new as you're going to find!!
#73
ONLINE
Posted July 13, 2013 - 06:29 AM
Niiiice blower! Did you get the flag for the lift rod? Those get lost easy.
#74
OFFLINE
Posted July 13, 2013 - 07:47 AM
How about that I finally got something I dont have to work on before I can use it ,,,,, I dont think I got the deal of a lifetime with these and I paid the asking price without a blink but,,,,,,,ya suppose they was worth a buc and a half a piece? That blower is sweet 79360 model all original paint and decals. Yes I have the flag! and the helper spring for a manual lift tractor. The blade is also complete including a nice rear mount, the one on the tractor has noticeable wear from running a tiller.
- twostep said thank you
#75
OFFLINE
Posted July 13, 2013 - 11:37 AM
bugger thats cheap... nice find..... Now go get the sweeper so when you pave your driveway you can sweep it..
