I finally bought a welder
19 replies to this topic
#16 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted March 02, 2010 - 09:27 PM
I think the Argon CO2 mix would be best for steel. i'll check the chart on the welder at school tomorrow. It tells you how to set it up for the most part.
#17 olcowhand OFFLINE
  • 37,719 Thanks
  • 30,340 posts
Posted March 03, 2010 - 03:06 PM
I use straight argon on aluminum,but never tried it on steel.Argon/ Co2 mix works best on steel , at least that's my view on it.
Yep, as I understand, that's the best for steel, but not affording both tanks, I do decent on steel & TIG with straight argon. I need the straight argon for aluminum welding.
#18 mjodrey OFFLINE
Posted March 03, 2010 - 07:20 PM
So does straight argon pretty good on steel ?
#19 olcowhand OFFLINE
  • 37,719 Thanks
  • 30,340 posts
Posted March 03, 2010 - 07:33 PM
I had absolutely no problems. My gas supplier says many people use straight argon on steel to save needing 2 tanks.
Edited to add: With my TIG, I can weld steel, aluminum, stainless & more with straight argon.
Edited by olcowhand, March 03, 2010 - 08:43 PM.
#20 mjodrey OFFLINE
Posted March 03, 2010 - 07:42 PM
I will have to try that.
