How Do I Keep Grass Out Of My Garden!?!
30 replies to this topic
#1 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted June 01, 2013 - 08:30 PM
Ok, my garden so far this year was doing good until the grass started coming back an steeling all the nutrients. I don't know what to do, I am trying to keep up with just picking it but there is so much! I've heard that vinegar might kill it without hurting the plants, is that true? I am going to try spraying a bit of roundup inbetween the rows to see if that will kill the grass but not the plants. Is there something I can do in the off season to help keep the grass from growing back? Is a ditch around the garden really helpful or maybe a cheap landscaping rail around the garden helpful? Thanks for y'all's help, and looking forward to replies!
  • hamman said thank you
#2 olcowhand ONLINE
  • 39,669 Thanks
  • 30,971 posts
Posted June 01, 2013 - 08:36 PM
Even a miniscule amount of roundup will kill your garden plants, so I wouldn't try that unless you can completely cover your veggies before spraying. You have a tiller?    As far as after the garden is done, you could sow winter wheat as a cover crop.  It will help keep other weeds/grass down, plus hold your soil.  Simply spray it or plow it under in the spring.
#3 CADplans OFFLINE
CADplans
  • 219 Thanks
  • 213 posts
Posted June 01, 2013 - 08:43 PM
Put the Roundup on with a paint roller, spray will drift.
  • Alc and hamman have said thanks
#4 Traill95 ONLINE
Traill95
    Traill95
  • 1,828 Thanks
  • 1,003 posts
Posted June 01, 2013 - 08:52 PM
As Santa says,,,, Hoe, Hoe, Hoe
  • hamman, JDBrian and New.Canadian.DB.Owner have said thanks
#5 HowardsMF155 ONLINE
  • 2,830 Thanks
  • 2,972 posts
Posted June 01, 2013 - 09:09 PM
Till it if possible.  Spray will drift and kill your desired plants. If you don't want to keep tilling, you could try putting down some sort of cover material.  Any sort of mulching material will work well.  Is part of the problem that you have a running type of grass that is getting in from the lawn around the garden?  Your best bet there is still the tilling.
#6 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,279 Thanks
  • 2,809 posts
Posted June 01, 2013 - 09:13 PM
Roundup when there is absolutely no wind at all. It will kill your veggies. use a tiller or a cultivator ( hand driven) to get all the grass out. A guy I used to work with would roundup his entire garden five weeks before tilling and then till it and round up again 3 weeks before planting. You need to water the roundup he said so it will be gone a week before you plant. I never tried it. to afraid I would ruin my garden. We just take and till and cultivate it all summer long. Wife will have to do most of it this summer. Good luck. Roger.
#7 jms180 ONLINE
jms180
  • 1,355 Thanks
  • 1,497 posts
Posted June 01, 2013 - 09:28 PM
I use the tiller one or two times a week and as Traill95 said Hoe Hoe Hoe.
#8 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted June 01, 2013 - 10:31 PM
Tiller, roundup a couple/3 weeks before planting, small tiller thru the growing season.
I have some plastic, but that can cause problems in high wind areas.
I have heard straw or cardboard and just till it in next year but have never tried it.
#9 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted June 01, 2013 - 10:46 PM
@ howardsmf155 yes it is running in from the yard and I can't seem to stop it, thanks all for the advice, and I guess I'll try and keep after it with a tiller and a hoe.
  • HowardsMF155 said thank you
#10 CADplans OFFLINE
CADplans
  • 219 Thanks
  • 213 posts
Posted June 01, 2013 - 10:52 PM
Smother the grass with
#11 grnspot110 ONLINE
grnspot110
  • 4,024 Thanks
  • 2,594 posts
Posted June 02, 2013 - 05:22 AM
I mulch mine, controls weeds & holds moisture (not a problem so far this year).
I use "aged" sawdust, since it's readily available to me, but newspapers, grass clippings (from herbicide free yard), straw, etc. will work.  Some even use black plastic (don't use clear, as it will break up in the sunlight).
Lowell
#12 JDBrian OFFLINE
  • 9,599 Thanks
Posted June 02, 2013 - 05:54 AM
I have grass problems too and I don't even have a lawn. It comes in by bird droppings or seeds blown in from neighbours yards. I just keep yanking it out and tilling it in. I haven't resorted to chemicals near the gardens but I have a small garden so it is manageable without them.
#13 HowardsMF155 ONLINE
  • 2,830 Thanks
  • 2,972 posts
Posted June 02, 2013 - 06:33 AM
I looked at your location and happened to think about that.  Yes, I think your best bet is to establish a zone around your garden where you till on a regular basis.
#14 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted June 02, 2013 - 06:35 AM
The way I do it is, till if possible, but don't till to deep, you don't want to destroy the roots your plants have put out. And use Preen in between the rows. Grass comes from 2 sources, either comes up from a root or seed. If from the root about the only way to kill it, is to till it under. I use the TB Horse between the rows and the little mini tiller between plants, like cabbage and squash. After the plants have come up from seed, I use Preen in between the rows to stop the weed and grass seed from germinating. Things like Morning Glory and Pigweed I pull those up, it's much better to do this while the soil is wet, so you get as much root as you can.
Another thing I do is to bag my grass and pile it in between the rows, I will pile it over a foot deep, and let it break down. You want to do this before the grass goes to seed. I also use roundup around the edges to keep the grass from creeping back in. Now my onion and tomato beds, I get down on my hands and knees and weed them, then the tomato bed I mulch it with wood chips I get from the city.
I will till several times during the year just to turn the grass under, grass and weeds need sunshine to keep growing, so by turning it under you can kill it off. It has taken me several years to kill off all the grass in my garden.
The name of the game to keep after it, this year has been hard because it rains every week.
  • bigcountry48 said thank you
#15 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,620 Thanks
  • 9,436 posts
Posted June 02, 2013 - 06:42 AM
Oh, I'd say; stop throwing your roaches there!!! Sound about right? :rocker2:
