T-92 And T-95 Interchangeability?
3 replies to this topic
#1 TimW OFFLINE
TimW
  • 414 Thanks
  • 271 posts
Posted June 01, 2013 - 06:15 PM
I have a later model PK 1416 and the T-95 four speed has eaten several gears.  I have access to a good T-92.  I have not done a lot of measuring or comparison.  Will they interchange in the same driveline?  I never get lucky on things like this, so I think I already know the answer.  Thanks in advance.
#2 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted June 01, 2013 - 09:40 PM
Hi,
So you have a fiberglass pk with the infamous clutch and 4 speed transmission?
If you do, then installing the old style clutch and T92 3 speed is not an easy thing to do.
If you have a long hood PK 1982-1984 then to change to a T92 is easier, you will need a new clutch disc as the splines are different between the 2.
Good luck. Chuck
  • TimW said thank you
#3 TimW OFFLINE
TimW
  • 414 Thanks
  • 271 posts
Posted June 01, 2013 - 10:32 PM
Mine 1614 is the long hooded metal one, it has a decal on the hood also that denotes "4 speed".  I have the clutch disc and some other parts for the 3 speed T92.  If it is somewhat doable without a ton of parts searching, I will start to head that direction.  Other than the clutch disc and transmission, would you happen to know of anything else that might come into play with the switch?  Are the drive shafts the same spline and length?
#4 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted June 02, 2013 - 03:01 PM
Hi,
I think the only parts you will need are the clutch disc and the T92.
Chuck
