54" blade..power angle problem!!
7 replies to this topic
#1 JDGIMPER1 OFFLINE
JDGIMPER1
  • 1 posts
Posted November 03, 2010 - 01:45 AM
hello............
i just got a 54" power angle blade for my 1983 John Deere 318. to raise up and down works like a charm. but try the power angle and it moves but it is soooooo sloooooooow. when it kicks in and starts moving, it sounds as if it is really straining the hydro system. pulls the motor RPM's downand all. takes 45-60 seconds to go from full left to full right. PLEASE HELP!! i am a paraplegic of 27 years. this winter i am ready to have some fun and participate in the season. i need this fixed!!! ANY ADVICE ??
thank you for any info you may provide.
signed GREEN with FRUSTRATION!
#2 mjodrey OFFLINE
Posted November 03, 2010 - 05:16 AM
Jdgimper1 :welcometogttalk:
Someone should be along with an answer for you shortly.
#3 Bolens 1000 ONLINE
  • 15,291 Thanks
  • 18,235 posts
Posted November 03, 2010 - 06:01 AM
Welcome to the Forum, JDGIMPER1 :wave:
I'm no expert on john Deere's so I'll wait for a John Deere guy to come along....
Enjoy the site!
#4 Grumpy OFFLINE
Grumpy
  • 732 Thanks
  • 619 posts
Posted November 03, 2010 - 06:55 AM
I have a 400 with a 54" blade but have never had any problems and have know ideas. Try here and someone will help. Weekend Freedom Machines
#5 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted November 03, 2010 - 08:16 AM
You might want to check if something is binding in the plow frame itself or if you have a cylinder or coupler problem. The easiest way to start would be to remove the tilt cylinder from the frame and try angling the blade by hand. Then try the hydraulic valve to move the cylinder by itself and see if the hydraulics strains to operate the cylinder. If the frame moves fine by hand but the cylinder struggles it could be either a problem with the cylinder or even a problem with the hydraulic couplers not opening up all the way and letting oil flow through the couplers causing a lot of hydraulic back pressure. Give this a try and see what happens. Good luck, Mike
#6 1971Deere OFFLINE
1971Deere
  • 48 Thanks
  • 66 posts
Posted November 03, 2010 - 08:48 AM
The pivot bolt could be over tightened. I had this problem on a manual blade I found on craigslist.
#7 olcowhand ONLINE
  • 42,372 Thanks
  • 31,796 posts
Posted November 03, 2010 - 09:25 AM
Sounds like a restriction in that circuit, maybe just as Mike said...a quick-coupler not opening up. If hoses will reach, swap hoses to other circuit. If the problem follows, then it's in the hose couplers, or in the hoses or cylinder itself. If it works fine after swapping, then it's in one of the female/tractor couplers.
#8 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted February 15, 2011 - 08:33 PM
I had a skidsteer that did the same thing, turned out I just need to extended the cylinder all the way and spray a little chain lube on it. Then it worked better. Another time had one binding and it just needed a new cylinder. Good luck!
Edited by middleageddeere, February 15, 2011 - 08:47 PM.
