Blade Conversion
8 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted May 29, 2013 - 09:24 PM
Doe anyone know how hard it would be to convert a manual blade to hyd ? 48 jd
larryd
#2 MH81 ONLINE
  • 29,933 Thanks
  • 29,752 posts
Posted May 29, 2013 - 09:29 PM
Larry, are you asking how hard it would be to add hydraulics to your snow blade?
Does the tractor have hydraulics?
  • larryd said thank you
  • 14,594 Thanks
  • 15,426 posts
Posted May 29, 2013 - 09:30 PM
Larry, I haven't looked a manual blade in quite a while, but I do have a couple hydraulic blades (54) to give you any info off of if you need it.
#4 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted May 29, 2013 - 09:38 PM
MH81 Yes my tractor has hyd , JD314
Brian thankyou 'll keep that in mind
I want a 48 or 54 blade so I'm trying to do things as inexpensive as possible as I'm on a fixed income
larryd
#5 MH81 ONLINE
  • 29,933 Thanks
  • 29,752 posts
Posted May 29, 2013 - 09:44 PM
Brian, do you have any pics of the blades to give Larry ideas?
#6 Texas Deere and Horse OFFLINE
  • 14,594 Thanks
  • 15,426 posts
Posted May 29, 2013 - 09:47 PM
I'll look thru my albums, but if I don't Ill take some tomorrow.
  • MH81 and larryd have said thanks
  • 14,594 Thanks
  • 15,426 posts
Posted May 29, 2013 - 09:56 PM
Larry, Here's a couple from the net, I will get you some more tomorrow, more detailed.
Sorry they're so small.
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 30, 2013 - 02:02 PM
Larry: I am assuming you have two spools on your 314 as I do on the 318(some of the 318's had a third spool/lever). To get the hydralic lift and angle you need to add another spool and run the plumbing to the front of your tractor.. I only have two levers and my brothers 420 with the 54" blade has a third lever to control the angle.
I considered doing that but the price of the blades(they seem to be hard to come by for ther 300 series and very pricey up here) (It's easier to find them for the 420-430?) and adding the spool and plumbing was more than I was willing to pay. Now that I have the Ford 1500 it's completly out of my mind. That's not to say I have not considered adding a front blade to the Ford? On that I think I would adapt a small pickup blade withe electric/Hydralic control.
Edited by JD DANNELS, May 30, 2013 - 02:11 PM.
#9 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted May 30, 2013 - 07:18 PM
J D the truck is sounding like a good idea . I just have the 1 lever with front hyd and deck lift . I would just have blade lift . I don't need hyd angle but would be nice .I did find a complete 54 with angle and lift for $650 but it was a complete rust bucket . I asked if they would take $400 but that was an ab solute no with no counter offer
larryd
Edited by larryd, May 30, 2013 - 07:23 PM.
