Just Joined
24 replies to this topic
#16 daytime dave OFFLINE
  • 5472 Thanks
  • 6779 posts
Posted May 30, 2013 - 08:38 AM
Welcome Jim.  You have us down pretty good.  Of course photographs and details will be appreciated down the road.  I'm glad you joined.
  • Sawdust said thank you
#17 Sawdust OFFLINE
Sawdust
  • 6797 Thanks
  • 3799 posts
Posted May 30, 2013 - 01:26 PM
Thanks everyone for all the comments. I'm a moderator over on http://www.thewhistlepost.com/forums/ & I know how important it is to recognize folks with a warm welcome, the willingness to help, & making folks feel a part of the family. Thanks again.
Now the good stuff. I bought this tractor back in the late eighties for $500. I had just previously bought 9 acres & needed something bad to cut about 3 acres 2-3 times a month. Being old school & appreciating the quality for old things buying something new never crossed my mind. I found this on Craigslist & long story short the guy lived just 3 sections down from me & became a good friend. The only thing I did was cleaned it up,replaced all the belts, replaced two bearings on the mower deck, had the seat reupholstered & made the lift on the back. I used this for about nine years as is until we relocated & sold the property. We had to move to the city to help take care of inlaws & I just stored it until now. I just jumped on the internet & found GTtalk & really got inspired to do something I never ever had time to do was to restore.
The only problem I had was the out put shaft on the Hydro tranny leaking. The previous owner told me he replaced the shaft seal & it worked for awhile then started leaking again. I took the tranny out & noticed the shaft was nicked in a few places where he took the seal out. I took it apart & slightly sanded & polished the shaft & put a new seal on it but again it still leaked. I'm thinking two possibilities, the shaft needs to be replaced or its not running true because of slop in the bearings. I have been told some play is OK I'm not sure on that or if so how much is OK.
I will begin soon taking everything apart & starting my restore. I'm going crazy looking at all the beautiful machines on here but I know I have a lot of dirt, grease & sand ahead of me. This of coarse is a MF12 with a Hydrostatic tranny, I have a geared starter, SSI, & a fluid reservoir under the seat. My serial # plate is worn too much to read the numbers so I don't know what year...I'm thinking early 70's ???? My deck I believe is beyond repair because of so many rusted holes in the deck...I always had trouble with the lead roller wanting to bend down because of the amount of rust in that area.
My plan is dismantle everything, clean, remove rust, fill pitted areas, prime & paint original colors. Because of your info I have found replacement decals, the hood trim I need & the steering wheel center trim. I'm also thinking about an exhaust stack as well like the ones I have seen on here. Right now the only questions I have is your thoughts on the shaft. Has anyone replaced the serial # plates & is there a serial # else where I can find. What is the difference between the white & red SSI decal & the black & chrome decal on the engine shroud.
Please any comments or suggestions would be appreciated. Thanks for viewing!
Jim
  • MH81, HowardsMF155 and Newpaws493 have said thanks
#18 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted May 30, 2013 - 02:49 PM
Jim, welcome to GTTalk.  You have a great machine there and I look forward to seeing the restore.  I haven't had to do anything about the hydrostatic shaft, so I can't help you there.  What I found on two of mine is that the "O" rings around the forward/reverse control shaft were bad.
#19 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted May 30, 2013 - 03:28 PM
Hi Jim, Glad you decided to join us.  How much play does the shaft have?  Maybe some Pic's would help to figure out the problem.
#20 Sawdust OFFLINE
Sawdust
  • 6797 Thanks
  • 3799 posts
Posted May 30, 2013 - 05:53 PM
Thanks Howard & Bill. Once I get the sheet metal off I'm going to take the engine off & PW the bottom. I'll take some pics then & post them before I dismantle the tranny. I also forgot to mention it's a Sundstrand model #902050 serial #01-HA 34905 if that helps anyone.
#21 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted May 30, 2013 - 07:55 PM
#22 Short_Circuit OFFLINE
Short_Circuit
  • 72 Thanks
  • 67 posts
Posted May 30, 2013 - 08:57 PM
:wave: Hello and welcome! Lots of good people here ready to help.
Welcome to the madness
I wondered why I didnt think I'd have a problem fitting in.... :rolling:
  • MH81 and Sawdust have said thanks
#23 ducky OFFLINE
  • 2326 Thanks
  • 4310 posts
Posted May 30, 2013 - 09:49 PM
Welcome to GTTalk Jim.
ENJOY!
#24 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted May 31, 2013 - 08:44 AM
Cool tractor, should look nice when ya get it done.
Find the numbers of the engine tins, should be stamped on there somewhere, then post them. The serial # on the engine will give a date of productions an dwe can maybe ball park year of tractor.
Depending on where you live in Cincy, we maybe close neighbors :smilewink:
#25 Sawdust OFFLINE
Sawdust
  • 6797 Thanks
  • 3799 posts
Posted June 01, 2013 - 12:10 PM
Thanks everyone for your comments I will be continuing my up dates over in http://gardentractor...f-12-rebirthed/
