Major 1050 Throttle Linkage Issues
29 replies to this topic
#16 JohnWR OFFLINE
JohnWR
  • 331 Thanks
  • 337 posts
Posted June 05, 2013 - 01:25 PM
Making some progress I found someone selling a used tra-12d out of another tube came its just missing the carb can I use the carb off my motor and will it bolt in to the 1050.
  • Bolens 1000 said thank you
#17 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted June 05, 2013 - 08:33 PM
The carb of the TRA-12D will interchange but the TRA-12D had an electronic ignition module that was different than the system used on the TRA-10D
You are going to have to re-wire the tractor to get that engine to run.....
  • JohnWR said thank you
#18 JohnWR OFFLINE
JohnWR
  • 331 Thanks
  • 337 posts
Posted June 05, 2013 - 08:43 PM
I re wired my entire Jetta GLI as long as i can find schematics that shouldn't be an issue the current wiring harness is kinda a joke as it is.
As for the carburetor will my throttle rod from the 10D change over? i am just trying to get an idea of that i need
The seller said it smokes a little bit but it ran smooth no knocks he pulled the head to de carbon the motor will carbon make these things smoke? as long as the cylinder wall and the piston look good i will just lap the valves and leave it be i will be rebuilding the 10D but now i don't have to rush and cut corners.
#19 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted June 05, 2013 - 08:49 PM
Everything on the carb (Linkage, spring, rods ) Should change over.
The engine should bolt right up , the only thing thats going to need attention is the wiring.
Sounds like the engine is showing signs of age if its starting to smoke but if it runs good and dosent smoke that bad it should get you by until you have the time to rebuild your other engine.
Excess Carbon buildup can be caused by worn/leaky piston rings.
#20 JohnWR OFFLINE
JohnWR
  • 331 Thanks
  • 337 posts
Posted June 06, 2013 - 07:19 AM
Ok this seems to be a well guarded secret and I can't find a thing but where is everyone buying Wisconsin parts like over sized pistons and rods and rings?
#21 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted June 06, 2013 - 08:30 AM
Many Times you can find some good deals on ebay.
Wisconsin Parts have never been cheap and are generally a bit more than most other brands of engines.
#22 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted June 06, 2013 - 04:05 PM
Here is Newrestorer's post.....he had a list of Wisconsin parts .....my memory was there were several pistons etc on the list....not sure what he has left....but worth a look.
I bought several items from Don......I highly recommend him.
http://gardentractor...rts#entry315405
#23 olcowhand ONLINE
  • 41,086 Thanks
  • 31,402 posts
Posted June 06, 2013 - 04:40 PM
Bob's Lawn & Garden, one of our site sponsors also has some Wisconsin parts.
#24 JohnWR OFFLINE
JohnWR
  • 331 Thanks
  • 337 posts
Posted June 07, 2013 - 09:24 AM
Thanks checked all the part numbers he doesn't have anything i need for the TRA-10d or 12d.
Ive been in contact with him sadly he does not have anything available at this time.
#25 olcowhand ONLINE
  • 41,086 Thanks
  • 31,402 posts
Posted June 07, 2013 - 09:46 AM
Contact this ebay seller.  He also has parts not listed.  http://www.ebay.com/...=&_trksid=p3686
#26 JohnWR OFFLINE
JohnWR
  • 331 Thanks
  • 337 posts
Posted June 07, 2013 - 06:53 PM
Just got back from a wasted trip got to the guys house and the motor was shot he had the head off and it looks like at some point someone rebuilt this motor and used the stock piston and just used over sized rings i could move the piston a good 0.030 in any direction. Why do these Wisconsin motors have to be so hard to find i just wanna mow my lawn :wallbanging:
#27 JohnWR OFFLINE
JohnWR
  • 331 Thanks
  • 337 posts
Posted June 07, 2013 - 09:33 PM
Just found it why does it have to be 6 hours away :wallbanging:
http://pittsburgh.cr...3852010029.html
#28 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted June 08, 2013 - 07:16 AM
Not a bad deal at all, Especially with the Starter
#29 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted June 08, 2013 - 07:53 AM
I feel your pain. I have been watching eBay for a s12d head for at least 6 months with no luck. It is a want and not a need, so I keep waiting for one to show up. Would rather find a spare s12d to keep for parts
#30 JohnWR OFFLINE
JohnWR
  • 331 Thanks
  • 337 posts
Posted June 08, 2013 - 10:40 AM
I wish I had a large frame there's a s14d on my local Craigslist. Now I just need to fine a way to acquire that motor any members from the Pittsburgh area wanna help a man out.
