Spark Question
9 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 28, 2013 - 08:28 PM
I have been working on my briggs and Stratton model 19 for a little bit now. and im having a spark issue. I cleaned the points and redid my coil and condenser wiring. I get good blue spark for couple cranks of the motor then it goes away for a little, then comes back.  is my condenser bad or Is it my points
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted May 28, 2013 - 08:37 PM
It sounds like a bad condenser to me.
  • 1978murray said thank you
#3 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
I'm not very familiar with a 19 offhand but is that one of those with replaceable spark plug wiring?
Ben W.
#4 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 28, 2013 - 08:44 PM
no the wire is stuck into the coil and is non replaceable.
#5 MH81 OFFLINE
Posted May 28, 2013 - 08:46 PM
Condenser if I had to hazard a guess.
#6 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 28, 2013 - 08:52 PM
that's what I was thinking will replace tomorrow. and see if my redneck heli coil spark plug thread repair will work until I can get a new head. the one head I have is cracked and I couldn't find anyone with a good tap. so I hammered one in. seems legit
#7 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted May 28, 2013 - 09:24 PM
With a meter you can test the condenser as its really just a capacitor (The capacity of all condensers is .16 to .24 MFD) If you don't have a meter that will do MFD, you can test it a different way with ohms and voltage, U-tube has a few just using a muti-meter, takes longer but you get there.
Which 19 do you have ? One of my books cover B&S from 1919-1981. Some have a coil with air gap some don't.
I would also recheck wiring and points to make sure it's not grounding out some where.
#8 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 29, 2013 - 07:55 AM
my 19 is around a 1963
#9 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted May 29, 2013 - 09:22 AM
Post a few photos (from different sides) if you can, off the top of my head their was a 19, 19D, ......
#10 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 29, 2013 - 04:28 PM
well i put another condenser on it so it now has 2. got really good spark. now to wait for the new head to get here
