Kohler Engine Tools Question
8 replies to this topic
#1 Firemang OFFLINE
Firemang
  • 187 Thanks
  • 197 posts
Posted May 28, 2013 - 02:46 PM
I'm planning on tearing apart my Kohler K301 and doing a complete rebuild.  I've downloaded the engine rebuild manual and it says you need the Kohler tool kit.  I cant find it anywhere online to buy and no local shops have any either.  Any out there have any recommendations on what I need and what I really dont?
#2 Guest_gravely-power_*
  • Guests
Posted May 28, 2013 - 03:21 PM
A complete Kohler service kit would cost $1000's if you could find one.
All you need is a fairly well stocked tool box.
  • Firemang said thank you
#3 Clippnalawn OFFLINE
Clippnalawn
  • 113 Thanks
  • 105 posts
Posted May 28, 2013 - 03:28 PM
I have done a couple kohler k series engines... From the top of my head the only real "special" tools I used were a gear puller for the flywheel, feeler gauges for valves and crank end play, and a torque wrench for head bolts, rod bolts etc. a piston ring compressor, and valve spring compressor. I have a machine shop bore/hone the cyl, deck the block, flatten the head, polish the crank, grind the valves, and press the bearings for me. I may be missing a few things but I'm sure others will chime in. There's lots of very experienced engine builders on here. Good luck, it's pretty cool feeling the first time you tear something completely apart and put it back together and it runs!
  • HDWildBill and Firemang have said thanks
#4 EricFromPa OFFLINE
EricFromPa
  • 4,303 Thanks
  • 3,415 posts
Posted May 28, 2013 - 04:47 PM
The only other special Kohler tool you may need is if you want to put the Balance gears back in.They make a tool that holds the gears in time while you slip the crank in.Without that tool it is a real pain in the butt to get both balance gears set. Kohler timing gauge part #10355 or y-357
Personally I would take them out and leave them out.
If you must you can have the crank balanced.
Here 3/4 of the way to the bottom is the kit to balance a crank,they offer a balancing service also if interested.
http://www.kirkengin...ex.php#Products
Some info on how to balance a crank.
http://www.kirkengin...nstructions.pdf
  • WHdbJD said thank you
#5 Rock farmer ONLINE
Rock farmer
  • 1,316 Thanks
  • 1,282 posts
Posted May 28, 2013 - 06:51 PM
I saw a complete factory set in the case on EBay last week. I think it was a couple hundred bucks.
Joe
#6 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,316 Thanks
  • 10,291 posts
Posted May 28, 2013 - 06:59 PM
Do you know why the Kohler book says you need the tools? Who sells the tools? Kohler!!!
  • WNYTractorTinkerer and superaben have said thanks
#7 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,515 Thanks
  • 6,164 posts
Posted May 28, 2013 - 07:20 PM
Just say NO to the grenade gears!!
#8 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted May 28, 2013 - 07:38 PM
Sure, you can buy Kohler engine tools, but you will find a lot of things in there that you can even create yourself with a little ingenuity.
To put it in a really simple way, I rebuild engines from full rough shape to bare bones to running shape.  Even "specialty" tools (like bearing drivers, reamers, etc) can be bought in standard sets if you decide you need to go that far.
The only special tool I bought for one purpose and swear by is a Briggs aluminum engine starter clutch remover.  That thing saves dinging up those little screen mounting holes, and it is well worth the money.
Ben W.
#9 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted May 31, 2013 - 09:59 AM
And just for the 1 time use, many parts stores (Discount auto, Autozone, Napa, etc) will loan you tools for free/small cost. They USUALLY don't have lawn mower specific tools, but many small car engine tools will work for your purposes.
And if you NEED a brand specific special tool, you can always get it to the point of disassembly and run by the mower repair shop service door. Many a mechanic will spin off a flywheel or bolt with the impact for a $5.00 bill if they are not too busy...
I'm all for buying tools :wave: , but if you only plan to use the thing one time, there may be better options than buying an expensive tool...
But EVERYBODY needs a good basic set of quality tools..........
