Fuel Usage
4 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,286 Thanks
  • 1,753 posts
Posted May 27, 2013 - 09:12 PM
Anyone know about how much fuel a hour a kohler 18hp command uses? The OEM tank looked big but that might have just been for convenience. It won't work with my set up. I need a smaller tank but don't want to go so small I have to fill up every hour.
posted with tapatalk 4
  • larryd said thank you
#2 John@Reliable OFFLINE
John@Reliable
  • 1,296 Thanks
  • 1,416 posts
Posted May 27, 2013 - 09:24 PM
Rule of thumb maybe? Gallon per hour heavy use, I think would be safe.
#3 CADplans OFFLINE
CADplans
  • 219 Thanks
  • 213 posts
Posted May 27, 2013 - 09:28 PM
It mostly depends on the load on the engine. I can spread fertilizer for an hour with a gear Kohler powered tractor, and only use a quart of gasoline. (I just did that)
Put a mower on the tractor, things change!!   :biting_nails:
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted May 28, 2013 - 08:13 AM
I don't have a Kohler, but know my 318 w/Onan uses over a gallon per hour when mowing.
The Ford 1500 diesel with a foot more mower(5 ft) burns  burns just about  a gallon per hour.
Edited by JD DANNELS, May 28, 2013 - 08:16 AM.
#5 8tyman8 OFFLINE
8tyman8
  • 414 Thanks
  • 731 posts
Posted May 28, 2013 - 02:50 PM
Are welder Onan 18hp will run 4-5 hours at 3000 rpm with 3/4 load on 5 gallons of gas
