Can You Put A 8.50 Rim On 26X12-12 Tires
9 replies to this topic
#1 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted May 26, 2013 - 10:34 AM
will they fill out or get taller
#2 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 26, 2013 - 11:12 AM
The rim size on a 23x8.50-12 tire is 12x7. The rim size on a 23x10.50-12 is either 12x7 or 12x8.5. On a 26x12-12 tire the rim size is usually a 12x8.5. However, you can get a 26x12-12 on a 12x7 rim if you don't mind a lot of tire bulge. Hope this helps.
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 26, 2013 - 12:23 PM
So I can't put 26 12 12s on my 23 10.5 12 rims with no issues or abnormal looks? I'm sure I've got the wider of the two.
Sent from my HTC One VX using Tapatalk 2
#4 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 26, 2013 - 12:26 PM
I think Casey typo'd on the rim size for 26x12x12 tires.  They normally mount on 10.5 wide by 12" tall rims.  So David, your rims are perfect.
  • wvbuzzmaster said thank you
#5 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 26, 2013 - 01:40 PM
If this is for a pulling tractor you want to mount a 26x12x12 tire on a 13" wide rim measured between the beads. This gives the best side wall profile and keeps the tread as flat as possible.
#6 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 26, 2013 - 03:13 PM
Thanks for the additional information on the more conventional rim sizes for the 26x12-12 tires. I know a lot of guys have used them on 12x8.5 rims, but I also know I always prefer straighter sidewalls on my tires, and do not own anything with 26x12-12 tires.
#7 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 26, 2013 - 04:35 PM
Usually a taller tire will give you a bit more leeway for rim width than one with a shorter sidewall. You may be able to find the recommended rim width for the tires you are using by going to the manufacturers site.
#8 Grumpy ONLINE
Grumpy
  • 748 Thanks
  • 624 posts
Posted May 26, 2013 - 04:51 PM
I have 26x12-12 on 8.5 rims. They looked a little funny at first. I made spacers to move the inside of the rear tires  to be inline with the inside with the front tires. I run 5 psi in the rear tires and  It plows grate. No weight at all.  Pulling I want the widest rim the rules let you run. but I wouldn't go over 13"
Edited by Grumpy, May 26, 2013 - 06:26 PM.
#9 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted May 26, 2013 - 10:48 PM
thanks
#10 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted May 28, 2013 - 04:25 PM
We run 14 wide aluminum rims with 26 12 12's Makes a shorter fatter tire easier than changing out the gears
