Ariens Gt Rear Axle Felt Seal
4 replies to this topic
#1 Wm McNett OFFLINE
Wm McNett
  • 126 Thanks
  • 169 posts
Posted May 25, 2013 - 04:43 PM
Still waiting on the parts I ordered on 5/14 from Jacks.
I did a little searching but can't find the answer to, Where does the felt seal GO?
On my GT19 that I'm replacing the rear axle bearing, there was a felt seal on the outside of the hub and Caliper Mounting Plate
on the other rear end I bought without hubs the felt seal was inside behind the Caliper Mounting Plate, I was thinking it may have ended up there when Joes Outdoor Power power washed it.
my best guess playing around with the pieces is, it gets inserted into the outboard side of the bearing cone, inside the cage that holds the rollers, then the Caliper Mounting Plate is bolted on, then the hub.
#2 shorty ONLINE
shorty
  • 5,468 Thanks
  • 5,257 posts
Posted May 25, 2013 - 09:07 PM
I think there is a good diagram in the parts manual. I will see if I can find it for you.
#3 shorty ONLINE
shorty
  • 5,468 Thanks
  • 5,257 posts
Posted May 27, 2013 - 05:05 PM
This is the diagram that I found in the parts manual.
Edited by shorty, May 27, 2013 - 05:06 PM.
#4 Wm McNett OFFLINE
Wm McNett
  • 126 Thanks
  • 169 posts
Posted May 28, 2013 - 03:42 PM
I looked in the old repair manual, 1974-1975 before they had brakes, seat switches, interlocks, and when they had the good tapered roller bearing (Timken) front wheels, the felt seal is shown on the outside.
http://apache.ariens...s/PRM 31000.pdf
Now that my grass is going to seed. I sent Jacks a message stating I checked the Ariens 03164200 gasket on a few other sites, they said it was no longer available, they replied.
Unfortunately this is NLA from the supplier. I will delete this off of your order, credit your card, and ship the order as soon as possible. Thank you for your patience.
#5 Wm McNett OFFLINE
Wm McNett
  • 126 Thanks
  • 169 posts
Posted May 28, 2013 - 07:50 PM
While sitting around waiting and pondering, I thought why not an O-Ring.
grabbed my box of Harbor Freight O-Rings
http://www.harborfre...ment-67554.html
and came up with a 326 3/16 thick 1-5/8 ID 2 OD
Don't see any reason why it wouldn't work.
Then again a 327 3/16 x 1-3/4 x 2-1/8 could work as well but it only gets expanded a little
