Well Now I've Done It!
10 replies to this topic
#1 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted May 25, 2013 - 10:46 AM
Well after the battery terminal issue and belt blowing for the mower, I fixed all that, went to now and no pto!!! WTF I say, check for power, all good, ohm the coil.... DOH!!
Pulled off the pto and it is destroyed.... Seems something warped and it was hitting in a few different places, needless to say... Its junk... But i have a few spares thank goodness and will be making a brand new "bellhousing" to hold the pto and a brand new crank adapter just because...i dont like it. And at the same time install the factory pto.
#2 KC9KAS ONLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted May 25, 2013 - 10:59 AM
There is just no end to a mans work!
I always said, "If you own something, you will always have something to repair"!
#3 JDBrian ONLINE
  • 9,629 Thanks
  • 14,153 posts
Posted May 25, 2013 - 03:02 PM
Sometimes it's all you can do just to keep things running. It'll pass and then it's trouble free tractor seat time for you!
#4 UncleWillie OFFLINE
  • 16,094 Thanks
  • 8,903 posts
Posted May 25, 2013 - 03:08 PM
Go do work son. I hate it when my stuff breaks. I don't mind other peoples stuff going wonky but I hate it when it is mine.
  • Chopperhed said thank you
#5 KennyP ONLINE
  • 40,037 Thanks
  • 46,731 posts
Posted May 26, 2013 - 07:48 AM
Dang! You're just having all kinds of issues going on, Keith! Glad you have spare parts to fix it!
#6 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted May 29, 2013 - 07:03 PM
Well we're on the road to recovery!!! Happy joy!!! Got the shaft/flywheel all trued up and the new adapter plate made and mounted . it looks better, and runs way smoother too. ( found the factory adapter plate was WAY out on the flywheel and this ruined the clutch. I thought it was the clutch pulley that was all wonky, so much for thought..,.
Anyways here are a few shots of it all together mostly.
  • MH81 and sacsr have said thanks
#7 IamSherwood OFFLINE
  • 8,395 Thanks
Posted May 29, 2013 - 07:16 PM
Looks like a good fix you did there. That didn't take you long. :thumbs:
I find it's always rewarding to improve on those things that fail. Eventually
they all do.
#8 KennyP ONLINE
  • 40,037 Thanks
  • 46,731 posts
Posted May 29, 2013 - 07:28 PM
Nice looking fix ya got there!
#9 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 30, 2013 - 10:10 PM
Actually, I Like it when I see a new car/tractor/vehicle broke down, or wonky, When I drive/ride/mow by.
I used to get the biggest kick from seeing a new car on the side of the road, and my old 71 F150 kept powering on,
Of course this was the late 90s
Edited by Chopperhed, May 30, 2013 - 10:27 PM.
#10 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted May 31, 2013 - 03:40 AM
"Geez don't mind me if I find humor in your miss fortunes" Don't worry guys I won't ....
Got all the sheet metal on last night , even fixed a boo boo that it was developing ( I soldered it back on and repaired the rust and dent with lead ) Seems the nose mounting point decided to tear at the shell so it was the correct time to repair, now all I need to do is get'er painted tonight . Then mowin' duty tomorrow !!
#11 KennyP ONLINE
  • 40,037 Thanks
  • 46,731 posts
Posted May 31, 2013 - 04:03 AM
Good to hear it is going back together, Keith. Good luck with it!
