Paint Question
9 replies to this topic
#1 BairleaFarm OFFLINE
  • 1,354 Thanks
  • 1,783 posts
Posted May 24, 2013 - 09:46 PM
Is there a rattle can paint that acts like automobile paint? Meaning gas wont hurt it.
Sent from my HTC One VX using Tapatalk 2
#2 Nato77 OFFLINE
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted May 25, 2013 - 01:09 AM
I'm not aware of any automotive type paint in a rattle can, not saying there couldn't be. I've sold a few guys these http://www.preval.com/what-is-preval before. Kinda like a rattle can that you can put your automotive paint that has all the hardeners and activators in it to get a harder more durable finish..
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 25, 2013 - 06:01 AM
You can buy spray cans of paint intended for use on cars from companies like dupli color. I've used it before and it seems to be better quality than your average spray bomb. I can't say if it's as good as a true high end automotive paint. Does anyone know if there is a clear coat that would protect normal spray paint from harsh chemicals? That would be a good solution, as you wouldn't need to keep a stock of different colours.
#4 Arti OFFLINE
  • 1,363 Thanks
  • 989 posts
Our local Napa mixes auto paint (Enamel).. They will put it in a rattle can if you want them to , It is slightly expensive but I have used it to touch up rocker panels or small repair jobs. Also the local farm store sells Duplicolor as well as the big box stores sell it in the auto section in limited colors.
#5 crittersf1 OFFLINE
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted May 25, 2013 - 06:51 AM
Dupli-color makes a decent clear.
#6 BairleaFarm OFFLINE
  • 1,354 Thanks
  • 1,783 posts
Posted May 25, 2013 - 07:55 AM
I actually picked up a can of automotive rustolium. 2$ more a can test regular rustolium. They didn't give any big cans of dupli-color. I'll test this and see how it does.
#7 Canawler OFFLINE
  • 1,948 Thanks
  • 1,803 posts
Posted May 25, 2013 - 10:05 AM
Most engine paint in spray bombs is advertised as being chemical resistant.
VHT makes a lot of specialty spray paints and coatings that seem to be a little better quality than Krylon and Rustoleum. I'm sure they make something that is gas resistant.
  • 6,409 Thanks
  • 3,466 posts
Posted July 11, 2013 - 06:54 PM
DUPLI-COLOR ENGINE ENAMEL PAINT IS SOMEWHAT RESISTENT TO GAS IF CLEANED RIGHT AWAY. I also find dupli-color engine enamel rattle can paint to be the smoothest laying paint in a spray bomb.
#9 kingscarpion OFFLINE
  • 40 Thanks
  • 47 posts
Posted August 02, 2013 - 09:25 PM
try 2 stage in a can CLEAR made by
Spray Max 2K Rapid Cut-In Spot Aerosol Clearcoat. A premium two-component aerosol clearcoat that is designed to increase throughput. Rapid Spot Clear has excellent flow and leveling and air dries in 90 minutes.
  • 2K clearcoat in an easy to use aerosol with spray gun like results
  • Activate, shake and spray
  • Dries in 10 minutes (with heat lamp)
  • Quick and easy to buff
  • Dries to a high gloss finish
  • Excellent weather and chemical resistance
2 part so its excellent for holding up to weather and fuel!!
#10 esbbent OFFLINE
  • 422 Thanks
  • 247 posts
Posted August 02, 2013 - 09:31 PM
Ditto, on the Spray max 2k Rapid Cut in Clear. Great clear coat in an aerosol and hold up better than the duplicolor clear.
  • KennyP and kingscarpion have said thanks
