Mtd 990 Tires?
14 replies to this topic
#1 Brant2409 OFFLINE
Brant2409
  • 6 Thanks
  • 14 posts
Posted May 23, 2013 - 02:51 PM
I have seen a few different tire set ups on here for the 990.  I have heard that the standard can be hard to find.  Hoping people can tell where they find tires to replace originals and the different modifications everyone has done with different tire set ups.  Would be nice to know the different options out there.
#2 Jlaws OFFLINE
Jlaws
  • 556 Thanks
  • 368 posts
Posted May 23, 2013 - 04:45 PM
Brant , I posted a similar question about my 990 a short time ago , and I'm still not sure what I'm gonna do .
I've got a decent set of turfs , but I want to make a plow tractor out of it and like to find a set of 27 by 8.50 or 9.50 by 15" AG's .
I'm finding out that there hard to find .
I thought of going with a 12" rims and maybe a set of 26X12X12 tires but the 990 has a 4 lug hub and I'm not sure the newer 4 lug Cub Cadet rims I was thinking of using have the same lug  spacing ?
I may go that route , but I'm still going to keep my eye out for a set of 15" AG's .
If I find a tire source I'll let the 990 MTD guys know .
  • Brant2409 said thank you
#3 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted May 23, 2013 - 05:33 PM
I give up looking for Ag's for my Case 446, I just use chains if needed, a lot cheaper as I already had them :thumbs:
P.S. AG's do have a cool factor, that chains don't :smilewink:
#4 Oo-v-oO ONLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted May 23, 2013 - 07:48 PM
If you want to swap to more common 5 bolt hubs and 12" wheels, look for a set of Wheel Horse hubs. Make sure the axle size is correct, off the top of my head it is 1-1/8"?
  • Jlaws and Brant2409 have said thanks
#5 Brant2409 OFFLINE
Brant2409
  • 6 Thanks
  • 14 posts
Posted May 23, 2013 - 10:11 PM
I remember reading on here somewhere somebody talking about using  the wheel horse 5 bolt but they didn't go into much detail.  I will be using my tractor for mostly tilling garden, food plot, and working trails so I would like something with more grip.
#6 VTXrider OFFLINE
VTXrider
  • 530 Thanks
  • 384 posts
Posted May 24, 2013 - 07:41 AM
I think you will find Brant that a set of 2-link chains and wheel weights has more than enough traction for tilling and pulling. I was amazed this winter and spring how well it plowed snow. I used to plow and disc my garden. I have skid steer tires and still needed chains, wheel weights and front weight to do the job.
  • Brant2409 and Sawdust have said thanks
#7 Brant2409 OFFLINE
Brant2409
  • 6 Thanks
  • 14 posts
Posted May 24, 2013 - 07:53 AM
I'm not so concerned about the plowing as I am about the tilling and working food plots and timber trails also I might try using it to disc some.
Edited by Brant2409, May 24, 2013 - 07:54 AM.
#8 AverageJoe OFFLINE
AverageJoe
  • 105 Thanks
  • 143 posts
Posted June 01, 2013 - 10:13 PM
Just posted this, but in case you don't read that thread...
http://gardentractor...tires/?p=325676
#9 SammyRye OFFLINE
SammyRye
  • 41 Thanks
  • 45 posts
Posted June 05, 2013 - 06:40 PM
Tires are available from Carlisle:
Turf Master / Multi-trac
Tire Size Code Ply Diameter Width Width @ 10 MPH PSI Weight
MTCS* 27 x 8.50 - 15 574348 4 26.6 8.5 7.00 1230 30 25.1
MTCS* 27 x 8.50 - 15 574356 6 26.6 8.6 7.00 1570 45 25.4
MTCS* 27 x 10.50 - 15 5743H6 4 26.9 10.2 8.00 1320 30 29.1
MTCS* 27 x 10.50 - 15 560371 8 27.0 10.5 8.50 1870 60 32.6
Unfortunately, they don't make the ag tires anymore.
You can get 27 x 10.50-15's in skid steer tires, but they're 8 ply, and very pricy. Might be able to get a couple of used tires from a dealer pretty reasonable.
Good luck - Rich
  • AverageJoe and Brant2409 have said thanks
#10 AverageJoe OFFLINE
AverageJoe
  • 105 Thanks
  • 143 posts
Posted June 05, 2013 - 10:08 PM
200 biscuits apiece for those 27 x 8.50 - 15s!  Ouch!
#11 SammyRye OFFLINE
SammyRye
  • 41 Thanks
  • 45 posts
Posted June 06, 2013 - 07:05 PM
Yup - they're not cheap. That's why I bought some "end-of-the-year" close-outs at WallyWorld - P235/75R15's. A little narrower, but that's ok, 'cause they were only $35 each. Filled them with 10 gallons each of RV antifreeze - added another 85 lbs. per wheel for traction. So far, they're working well. Rich
  • sacsr said thank you
#12 EricFromPa ONLINE
EricFromPa
  • 4,004 Thanks
  • 3,265 posts
Posted June 07, 2013 - 01:13 AM
These are nice looking tires.If you were to shave the inner tread a bit they would almost be the same as the Carlisle Tru Power tire but in 6 ply instead of 4 ply.Carlisle loader tires have 17/32" and the 12" Tru Power is 20/32" so they're also pretty close for tread depth.
27 x 8.50 - 15
$145.85 each
  http://www.millertir...ac-chief-6-ply/
Or $125.00 free ship  16/32" 6 ply
http://www.ebay.com/...=item335518cd53
#13 Canawler OFFLINE
Canawler
  • 1,950 Thanks
  • 1,806 posts
Posted June 07, 2013 - 08:21 AM
There are several threads on MTF about why skid loader tires are way too stiff for use on a garden tractor. A lot of people tried them and I don't remember anyone liking them.
I haven't tried them before but I just want anyone considering them to do some homework before such an expensive purchase.
  • AverageJoe, Texas Deere and Horse and sacsr have said thanks
#14 AverageJoe OFFLINE
AverageJoe
  • 105 Thanks
  • 143 posts
Posted June 07, 2013 - 12:21 PM
I think one of the guys was "Stoneykill".  He felt like they had ruined the ride of the tractor.
Rich's 235/75R15 is probably the most economical solution.
#15 HALFSCALE ONLINE
HALFSCALE
  • 506 Thanks
  • 534 posts
Posted June 08, 2013 - 05:41 AM
I know the ag tires look cool ,but I can wait until someone comes out with them. I know there is a small tire manufacturer ,that is having some of the more obscure tires done in china, if enough different people get on threads like this, they may realize there is a big enough market to make it worth while.
I've been begging for triple rib 18- 8.50's , likes on the front of the long frame MTD hydro's .
