Briggs 5Hp Seized
8 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 23, 2013 - 12:48 PM
i have been working on a modified 5hp briggs for a guy, well anyway it has a shaved head, cut eyebrows, ported and polished intake and exhaust, and new carb jets. i got it 90% together and decided to test it out. dumped gas into carb and it fired, i did this couple times just for the heck of it, it never over revved or made a funny noise. but i went to pull it again to do another run and it just froze.  u cant turn the motor at all.  took plug out thinking i hydolocked it, still seized. took head off everything looks fine exhaust valve is open and all but motor will not turn. any ideas
#2 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted May 23, 2013 - 12:52 PM
Missing any tools >> only kidding :D
I wouldn't play with it anymore, time to start breaking it down to see whats going on for sure.
#3 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted May 23, 2013 - 12:58 PM
What was the tolerance on the piston and bore ??? the pistons are undersize so when they warm up they will be right in the bore is you have a over size piston it can heat up and get wedged in the bore .. Did you put oil in it ?? I have seen that done before ..
#4 brahlf OFFLINE
brahlf
  • 11 Thanks
  • 24 posts
Posted May 23, 2013 - 01:10 PM
One of two things.
Piston is stuck in bore, too big. Or ran without oil and seized the rod to the crank.
#5 HDWildBill OFFLINE
  • 8,975 Thanks
Posted May 23, 2013 - 03:36 PM
One of two things.
That's what I was thinking no oil.
#6 KennyP ONLINE
  • 38,302 Thanks
  • 45,899 posts
Posted May 23, 2013 - 03:41 PM
No oil or too tight tolerances!
#7 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 23, 2013 - 04:23 PM
nope brand new oil, and yes its the right amount. also it has stock piston and rings.
#8 KennyP ONLINE
  • 38,302 Thanks
  • 45,899 posts
Posted May 23, 2013 - 04:46 PM
Any possibility the rod is 180 out?
#9 MH81 OFFLINE
Posted May 23, 2013 - 10:23 PM
Are the rings new?
