* * * * * 1 votes
My Tractor Build
88 replies to this topic
#76 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 07, 2013 - 09:17 PM
Yes but they are rough and the standard rims don't accept the average gt wheel weights
Sent from my SCH-I535 using Tapatalk 2
#77 KennyP ONLINE
  • 38,222 Thanks
  • 45,861 posts
Posted September 08, 2013 - 05:26 AM
I like the Sterling Yellow. I hope you get the hubs figured out.
#78 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted September 08, 2013 - 07:19 AM
Those new meats are mean looking. Will they not fit on the 4 lug cub rims?
#79 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 08, 2013 - 09:07 AM
They will but then I have to modify the rims to fit wheel weights
#80 UncleWillie ONLINE
  • 15,660 Thanks
  • 8,758 posts
Posted September 08, 2013 - 08:53 PM
Nice build. Cant wait to see it finished.
#81 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted September 09, 2013 - 09:12 AM
what does that mod include?
I want to see those meats on this tractor and it pulling a plow in less than two weeks!!!!
#82 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 09, 2013 - 10:53 AM
Drilling holes for the weight bolts. The valve stem is awful close you the bead as well. I wonder if they make 5 lug hubs off another model that would fit this.
#83 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 22, 2013 - 01:34 PM
I do believe I burnt the rear end up. Alot or heat alot of whining this may be the end of this pretty thing. Off to storage she goes.
#84 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 22, 2013 - 01:35 PM
Had to push it on the truck
#85 MH81 OFFLINE
Posted September 22, 2013 - 04:04 PM
I'm wondering if you've got a blockage in there somewhere. I suppose it could've given up, but it had been a real workhorse for you up until now?
If it is the end, Thats a shame. At least she had one more glory ride.
#86 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 22, 2013 - 04:08 PM
It was whining hard and I pushed it harder. Tires should spin. Traction should be the limiting factor not a week hydro
#87 IHCubGuy ONLINE
IHCubGuy
  • 1,508 Thanks
  • 1,587 posts
Posted September 22, 2013 - 06:07 PM
I am with Alan on this one.  I don't know the situation you had today but I would not be so quick to condemn it.  Maybe the filter plugged up and is bypassing or it has some other issue going on.  You did just change all the fluids and filter in it did you not?
Give us a run down on what exactly happened with it and maybe we can help you diagnose it.  You say it was whining and running hot, what happened next?  Did it just quit moving?  Details we need to figure it out.  It may yet be something very simple.
I can tell you my 107 with the wheel weigths on it will NOT spin here at our plowday very easy.  I can make the hydro growl pretty good and kill the engine if I try.
Keep your chin up and lets figure this out.
  • sacsr said thank you
#88 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 22, 2013 - 06:18 PM
I was plowing a field that has never been plowed so the sod was thick. I started out doing ok and I could tell it was pulling hard. I was harder on it than in sure it could handle but I really wanted to see what it would do. The more it bogged down the more it whined. It got weaker and weaker with every pass. Eventually it would do anything. I rolled it in the truck and brought it home. I let it cool down and tried it. It sounds fine. It will lift the plow if I pull up with my hand as I lift the hydro lever. Steering doesn't have the turning power it had. It will move a little in forward and hardly at all in reverse. I changed the fluid and filter months ago when I got it. I changed the filter tonight and the fluid looked and smelled ok.
#89 TAHOE ONLINE
TAHOE
  • 7,950 Thanks
  • 5,667 posts
Posted September 23, 2013 - 09:39 AM
Maybe a blockage or something in the pump so it's not pushing/building pressure?
I think you should do like you said Saturday, put it away for a while out of sight, work on the Snapper. Maybe good for ya to leave it be for a bit and get back on it later.
