* * * * * 1 votes
My Tractor Build
88 replies to this topic
#31 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted June 08, 2013 - 09:48 PM
I had to cut a big section out of the right step to clear the pedals. This came with a huge brake pedal that I need to modify.
My pull cable for the throttle isn't staying where I pull it so I need to figure something out with that. Were to put the fuel tank is another biggie. No room behind the dash or under the seat.
posted with tapatalk 4
#32 CADplans OFFLINE
CADplans
  • 219 Thanks
  • 213 posts
Posted June 08, 2013 - 09:56 PM
I just don't like the way this seat pan looks and I dont know how to make out look right. Hmmmm
It ain't the pan, it's the tires!!  You need bigger tires!!
WOOT!!   :dancingbanana:
#33 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted June 09, 2013 - 12:17 PM
This is true
#34 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted June 09, 2013 - 01:22 PM
:dancingbanana:
:yeah_that:
#35 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted June 09, 2013 - 01:30 PM
Nice rims where did you get those!
Sent from my SPH-L900 using Tapatalk 4 Beta
#36 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted June 09, 2013 - 02:37 PM
I am thinking maybe build a standing rack to hold the fuel tank above the muffler, with a cutout in the hood for the fill cap.  The heat could be shielded from the tank with either a metal stand-off shield, or wrap the tank with heat shield material.
Crude example:
#37 CADplans OFFLINE
CADplans
  • 219 Thanks
  • 213 posts
Posted June 09, 2013 - 03:19 PM
They are ATV takeoffs, very cheap!!  :dancingbanana:
#38 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted June 09, 2013 - 03:23 PM
That's awesome I'll have to look into that!
#39 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted June 09, 2013 - 04:26 PM
I thought about that danial even with a heat shield I'm scared lol.
#40 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted June 09, 2013 - 07:36 PM
If you wrapped it with good stuff made for this kinda thing, you could keep a tunafish sandwich in there for hours & not get food poisoning!
#41 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted June 09, 2013 - 08:09 PM
why not ditch the muffler, put a stack on and then put the tank where Daniel said?
#42 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted June 09, 2013 - 09:20 PM
I don't care for stacks. I think I'm going to be with it sd see how the tank fits
#43 Texas Deere and Horse ONLINE
  • 14,811 Thanks
  • 15,501 posts
Posted June 09, 2013 - 10:25 PM
FYI- The WH GT14 has 5 Ga. of gas sitting right in front of the exhaust port and muffler. I haven't heard of a single one blowing up, and they are plastic tanks.
  • olcowhand said thank you
#44 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted June 10, 2013 - 08:18 AM
honestly I'm not either... unless they are diesel. Another option (depending on if you plan to run a mower deck) would be to fab an exhaust like older gas tractors had down, under the belly and out the back.
edit: let me correct that... I don't like the LOOKS of stacks. I love the functionality of them. Get the exaust/sound up and out of the way. Forward facing are good for sound but the exhaust still blows back in your face. Side shooting is good for exhaust but bad for sound.
Edited by twostep, June 10, 2013 - 08:24 AM.
#45 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted July 07, 2013 - 03:12 PM
This is the first day I've really had a change to work this machine. My drag with 5 cinder blocks has strained every tractor I've had. I use it to test trannys. It did well. I re graded the driveway and moved a couple cords of firewood. I have noticed that the engine bay gets hot. The hood and dash are hot enough you can't touch it. The steering and seat combo are comfortable so I may be getting rid of the wheel horse hood and dash. All and all I'm.extremely happy with what I've got.Posted Image
Sent from my HTC One VX using Tapatalk 4 Beta
