* * * * * 1 votes
My Tractor Build
88 replies to this topic
#16 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 26, 2013 - 10:27 AM
No one is sharing my enthusiasm. POWER STEERING people.. I think it's a neat concept. Can you tell I'm excited lol
I'm working on the sheet metal today. I've got the dash tower trimmed and measured. I need to trim the dash tower tunnel for the drive shaft. I think the seat pan looks funny but I need to leave room. I hope to one day have 26" tires.
Sent from my HTC One VX using Tapatalk 2
#17 KennyP ONLINE
  • 38,394 Thanks
  • 45,939 posts
Posted May 27, 2013 - 07:35 AM
Hmmmmm? This could get interesting! Is this going to be a Wheel Cadet or a Cub Horse?
#18 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 27, 2013 - 11:26 AM
Decals will be a surprise. I've got several sheet metals to wh ags always liked there look. Also wheel horse and some cubs were red
.Posted Image
I've decided to use the dash tower from the cub so I have a place to mount my tank and battery. Under the seat had a lot of room but I'll need it for the rear pto.
Sent from my HTC One VX using Tapatalk 4 Beta
#19 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 27, 2013 - 05:53 PM
It took several hours but I got the hood mounted. I had to cut this part of the factory tower off and removed the bearing for the steering shaft.
Heres the wh dash mounted. More pictures to follow.
posted with tapatalk 4
#20 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 27, 2013 - 06:39 PM
Here is the steering bracket I moved down. If I put the muffler on it got the hood and the hood frame. As pictured I've trimmed the outlet and flipped it. I'm not interested in a stack so I've got something I need to do with it. Here is also a picture of the hood hinge.
There isn't enough roll in the wh for a tank. I don't want the fuel under the seat because I plan on putting a rear pto there for the tiller.
Here is how she sits tonite. The steering wheel is sitting high. I should be lowering it some but not until the seat pan and running boards are on.
  • Craig. and Dieselcubmike have said thanks
#21 KennyP ONLINE
  • 38,394 Thanks
  • 45,939 posts
Posted May 28, 2013 - 06:00 AM
It's going to be a different critter, that's for sure! Seems you are meeting the challenges thus far!
  • BairleaFarm said thank you
#22 twostep ONLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,538 posts
Posted May 30, 2013 - 09:31 AM
Looking good. And I would be excited about power steering too!!!
#23 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 30, 2013 - 11:30 AM
This thing is looking like crap. I'm just not happy. I also have a feeling the seat pan will be horrible since the spacing from the tires will be a lot.
I cut the exhaust pipes down so I could slide the muffler closer to the block. This allowed the hood to clear and the exhaust to exit out the bottom as it should.
I use a generic cable for the choke and throttle. Despite the red knobs the work well. At 7$ each the are also affordable. I've got a set of wh knobs somewhere around here. These are also long so they are nice for custom applications.
#24 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 30, 2013 - 11:35 AM
Remember I'm most of what I'm doing is just to get this gt going. I'm sure there will be several things ill want to change that I discover as I use it all summer.
I broke the hour meter so I'm running the clock on this used one I had. 10 days left and it should match the one I messed up.
  • MH81 and Craig. have said thanks
#25 olcowhand ONLINE
  • 41,198 Thanks
  • 31,429 posts
Posted May 30, 2013 - 11:41 AM
Somehow I missed this thread David!  And you changing tractors like underwear...... geez, I never noticed!  :rolling:    Interesting project!  Try to wear this pair of underwear a little longer please.  :smilewink:   And yes, power steering is something to be excited about.  That's why I've added it to 2 or 3 of mine.
#26 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 30, 2013 - 11:47 AM
I want to get this drivable with a seat so I can really play with it and see how she does. I wonder if I really even need a seat pan. Yeap probably do.
#27 MH81 OFFLINE
Posted May 30, 2013 - 06:06 PM
Fun to look at the progress so far. Thanks for the documentation.
Do you already have a tiller?
#28 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted May 30, 2013 - 10:23 PM
Kinda. I'm so far from mounting it that it's not even funny
  • Craig. said thank you
#29 83MALIBU OFFLINE
83MALIBU
  • 40 Thanks
  • 69 posts
Posted June 01, 2013 - 09:06 AM
I enjoy watching build posts and how other peoples tractors are being put together. Thanks for the posts.
#30 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted June 08, 2013 - 03:31 PM
I just don't like the way this seat pan looks and I dont know how to make out look right. Hmmmm
