Lmh Troubles
13 replies to this topic
#1 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted May 22, 2013 - 09:18 PM
I am working on a LMH carb that mounts to a Tecumseh OH160 engine
The guy I got the engine off of said it didn't run right, flooded out all the time, said he put a rebuild carb kit in it but no change.
I have taken the carb apart and there appears to be something missing.
The nozzle is a service nozzle, has been replaced.
Right beside the end of the body where the nozzle screws into there is a small threaded hole and nothing to go in it. (pic)
What if anything is suppose to go in there?
#2 IamSherwood OFFLINE
  • 8,391 Thanks
Posted May 22, 2013 - 09:27 PM
I looked at a few parts explosions. Doesn't show anything to go in there.
Edited by IamSherwood, May 22, 2013 - 09:28 PM.
#3 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted May 22, 2013 - 09:35 PM
I didn't take anything out of there but it sure looks like something is suppose to go in there.
#4 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted May 23, 2013 - 05:51 AM
Sure looks like a jet should be screwed in there , I wish I could be a help
#5 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,279 Thanks
  • 9,770 posts
Posted May 23, 2013 - 06:47 AM
I am listing a video that shows a Wahlbro LMH apart. It doesn't appear to have anything in that opening either. This video was made by one of our members. Perhaps he can chime in.
  • DH1 said thank you
#6 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted May 23, 2013 - 09:26 AM
Yes there should be something in there. That is where the main fuel jet goes. Which LMH carb do you have and i will get the part number for you.
#7 TAHOE ONLINE
TAHOE
  • 7,946 Thanks
  • 5,666 posts
Posted May 23, 2013 - 09:30 AM
I think he's talking about the small hole in the side of the main jet tube????
If I recall, there maybe a small brass jet that screws in there. I've seen them both ways with a small jet and nothing in there. Been a while since I've had my LMH apart.
#8 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted May 23, 2013 - 10:40 AM
That was the hole i was talking about. Some have the main there that is why it is threaded and some don't. That is why the carb number is needed. I would say the wrong kit was put in and that would be why it floods out.
Here is a pic of what should be there.
Edited by bhts, May 23, 2013 - 10:44 AM.
  • DH1, Alc, IamSherwood and 3 others have said thanks
#9 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted May 23, 2013 - 10:59 AM
Thanks Bob that makes sense now , maybe the kit had different parts the the the original  one
#10 TAHOE ONLINE
TAHOE
  • 7,946 Thanks
  • 5,666 posts
Posted May 23, 2013 - 11:23 AM
Gotchya!!!
I've seen them with a little plug type screw in jet, not one that sticks out like that. My LMH didn't have that type I can remember that fo' sho'
#11 Canawler ONLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted May 23, 2013 - 02:47 PM
Dumb question but what good would that jet do at that spot? It's just the fuel pickup point. All it could do is restrict fuel flow.
#12 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted May 23, 2013 - 05:47 PM
The carb I have has the adjustable high speed main jet.
MAYBE
Carbs with the adj needle valve on the bottom of the carb, don't have anything in that hole.
Carbs with the fixed jet, in that hole, would have a plug on the bottom instead of the adj needle valve.
#13 olcowhand ONLINE
  • 41,025 Thanks
  • 31,379 posts
Posted May 23, 2013 - 05:57 PM
I have seen carbs with a small jet screwed into that hole before, but I can't say what model carb or engine.  My memory isn't THAT good.  I do think it's as Doug said, on a non-adjustable carb.
#14 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,279 Thanks
  • 9,770 posts
Posted May 23, 2013 - 05:59 PM
Some of them have an adjustable main jet in the bottom of the bowl. They have the main jet up inside. Others just have a plug holding the bowel on.
