Briggs Ohv Blowing Compression Into The Crankcase
20 replies to this topic
#16 916 hydro OFFLINE
916 hydro
  • 114 Thanks
  • 139 posts
Posted May 24, 2013 - 06:32 PM
you described the guy im working on this for to a T i went out to look at the mower to see if it was maybey a simple fix and as i was picking up my tools he handed me a small ballpeen hammer and said dont forget your axe.
#17 916 hydro OFFLINE
916 hydro
  • 114 Thanks
  • 139 posts
Posted May 27, 2013 - 12:05 PM
id say blown head gasket what do you think?
#18 olcowhand ONLINE
  • 36,471 Thanks
  • 30,059 posts
Posted May 27, 2013 - 01:21 PM
Most I've seen that came out of one of those engines had head gaskets that looked JUST like that one, so that must be how they were made...right? :smilewink:   They dropped the ball on that design.  If they had put those 2 bolts both closer to the pushrod galley, then spread the rest equally spaced, there would be no problem.
#19 Guest_gravely-power_*
  • Guests
Posted May 27, 2013 - 01:36 PM
Yeah, look at the distance between the 2 head bolts that are across the cylinder. Even engineers screw up.
#20 916 hydro OFFLINE
916 hydro
  • 114 Thanks
  • 139 posts
Posted May 27, 2013 - 05:25 PM
anyone know the tourqe sequnce for these
#21 Watchdog OFFLINE
Watchdog
  • 132 Thanks
  • 113 posts
Posted July 16, 2013 - 05:28 AM
I just did a Briggs OHV. There was so much carbon build up that it broke loose and got between the intake valve and the piston and bent the push rod. That is pi@@ poor engineering.
I did one yesterday with a bent push rod (intake).  The post for the exhaust valve rocker had come loose (also a common problem on the B&S OHV), which throws the valve clearance out of spec and rendered the decompressor useless.  Some red loc-tite on the rocker post, new push rods and valve adjustments it was back in business.
Jeff
