226 With H46 Deck Help?
1 reply to this topic
#1 dropped82 ONLINE
dropped82
    Nut Case
  • 2,457 Thanks
  • 1,803 posts
Posted May 22, 2013 - 03:31 PM
Alright apparently I don't know how to mount this deck. I just removed it after mounting it the first time and now it mounted completely different. I'm wondering which way is correct? Does anyone have some pics of the 48" deck under a 200 series? The spot in question is the rear linkage. The first time I used the same links on both sides. This time I used a U shaped link on one side and some kind of funky shape offset link on the other. Its mounted but I'm still confused. Any help? I read the manual and unless I have pictures pertaining to which links I have I'm lost. I have different types of links and from what I understand it depends on what series tractor you have. Thanks in advance.
Eric
Sent from my XT897 using Tapatalk 2
#2 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted May 22, 2013 - 04:08 PM
The rear mounts don't need to be removed to mount or dismount deck at all, they are used to adjust deck height. You should have two "pins" that mount with case safely pin and two J bolts. The link below is the part breakdown. P.S. page 10 in book, but may be page 13 depending on your browser.
http://eastmanind.co...Amco=&tabid=196
  • dropped82 and Arti have said thanks
