Is there a cross reference number to a common bearing and seal for the 1185010 bearing and 1185296 seal in the gearbox?
Bolens Mower Deck Gearbox
#1
OFFLINE
Posted May 21, 2013 - 10:27 PM
#2
ONLINE
Posted May 21, 2013 - 10:30 PM
Take them to a bearing supply house and they should be able to cross them over for you.
Good luck.
- Nato77 said thank you
#3
OFFLINE
Posted June 01, 2013 - 01:04 PM
when it comes to finding the "hard to find " bearings, ive found that our local NAPA Auto parts store carries alot of bearings and seals, i havent had any problems finding what i need from them. good hunting...
#4
OFFLINE
Posted June 01, 2013 - 10:14 PM
I ended up finding a different gearbox to use on my deck. I haven't had time to tear one apart to see the size of the bearing, but when I do I planned on going to the local Napa to get them.
#5
OFFLINE
Posted June 04, 2013 - 02:09 PM
Hi,
Timken M12121 is the open ended needle bearing and the closed end is M12121W. I don't have the seal numbers.
Bud W.
#6
Guest_gravely-power_*
Posted June 04, 2013 - 02:16 PM
http://oldmowerparts...y-P2339007.aspx
