I Bought An Old Bolens Today I Am Not Sure What Model It Is
59 replies to this topic
#31 rando44001 OFFLINE
rando44001
  • 6 Thanks
  • 37 posts
Posted May 24, 2013 - 07:18 PM
Check your inbox, I sent you a PM Yesterday titled "Ignition"
I would also check with our site sponsors like MH81 suggested, they may have some good used gears at a decent price. NOS gears are expensive no matter where you go but $300 for a used set of gears seems ridiculous to me.
When the Wisconsin quits running have you taken out the plug to see if your getting spark?
The service manual below has a wiring diagram for your engine
http://gardentractor...ervice600-1155/
Yes I did no spark whatsoever, some of the wiring is also bad need to go though it? Cannot shut engine down by the key either. It takes a small screwdriver to ground it out. Can I do an ohms test on the packs to see if I get continuity?
Edited by rando44001, May 24, 2013 - 07:19 PM.
#32 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 24, 2013 - 08:03 PM
You may want to check your connections and ignition switch first before you think about the ignition module. If you have a volt meter you can check your connections for continuity
  • rando44001 said thank you
#33 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 24, 2013 - 08:05 PM
Hello All
I wanted to wish you a good holiday, and a safe one... I am going to try and contact Sam Bolens one more time to see what reaction
I get again? He was not to freindly last time, I need to get my other 1254 running. The mower under it is like a small bush hog I need knock some stuff down with it.
Funny you say that
Sam dosen't like me either.
Last time I dealt with him he said he was too busy to be bothered looking for the part numbers I gave him.
#34 rando44001 OFFLINE
rando44001
  • 6 Thanks
  • 37 posts
Posted May 24, 2013 - 08:18 PM
Funny you say that
Yea he told me the same thing, I found a sonny.bolens also see what kind of reply I get? Thanks for helping me out here some I like when they run hate when they don't. I told him I would never deal with him again? And I would spread the word about him, if he is tired of it, sell the business to someone more compassionate and appreciate quality Bolens tractors.
I am going to look it over again, I need a new building to store my toys in. If you hear of anyone with a plow board I could use one also.
Rando44001
  • Bolens 1000 said thank you
#35 rando44001 OFFLINE
rando44001
  • 6 Thanks
  • 37 posts
Posted May 24, 2013 - 08:23 PM
Rando44001
I need my 1254 to mow the graveyard off in West Virginia, also to keep up with other maintenance there. My family is all buried upon a mountain, road to it get rough. And i don't like being chased by rattle snakes while push mowing. I figured to get these going and pull them down on a weekend. These old tractors are great mountain climbers.
#36 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 24, 2013 - 08:29 PM
Although his website is still up, Sonny's Bolens is out of business
#37 rando44001 OFFLINE
rando44001
  • 6 Thanks
  • 37 posts
Posted May 24, 2013 - 09:55 PM
Aw man so much for that, I guess I will swallow my pride maybe. I bet he bought Sonny out? I got a response about him adding additional parts earlier this year. I wished I had my machine shop ready? I would just make everything mechnically and find other ways to go around him. I don't know. Parts are so darn expensive for these, half the items that wear I could make for half the cost?
Edited by rando44001, May 24, 2013 - 09:56 PM.
#38 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted May 24, 2013 - 09:57 PM
What are you in need of?
#39 rando44001 OFFLINE
rando44001
  • 6 Thanks
  • 37 posts
Posted May 24, 2013 - 10:02 PM
I may try this first if I do not find any wiring problems, I am going to thouroughly go through it replace bad wiring with the right wire ends and what it takes.
#40 rando44001 OFFLINE
rando44001
  • 6 Thanks
  • 37 posts
Posted May 24, 2013 - 10:04 PM
gears for 1254 is my first project, and paint, and a few worn items such as bushings and odds and ends, new wiring, clutch discs I believe that will get me started.
#41 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
This is for replacing  ignition breaker points..... The TRA12D does not have points.....
#42 rando44001 OFFLINE
rando44001
  • 6 Thanks
  • 37 posts
Posted May 24, 2013 - 10:09 PM
I also need to just go through everything I have my garden ready and the tractor is down, I need to also repair my tiller front seal is out on it.
#43 rando44001 OFFLINE
rando44001
  • 6 Thanks
  • 37 posts
Posted May 24, 2013 - 10:11 PM
I know I thought just maybe the pickup under flywheel would surfice as the coil, and create a spark through that device.
Edited by rando44001, May 24, 2013 - 10:12 PM.
#44 rando44001 OFFLINE
rando44001
  • 6 Thanks
  • 37 posts
Posted May 24, 2013 - 10:14 PM
I tried to remove the spark plug from the one I bought to pour some oil down in let it set foe awhile I twisted the threads off the plug I will have to use an extractor to remove it now.
#45 rando44001 OFFLINE
rando44001
  • 6 Thanks
  • 37 posts
Posted May 25, 2013 - 09:18 AM
I found these up north thought i would post them Sandusky amd Lansing Mich.
Edited by rando44001, May 25, 2013 - 09:19 AM.
