1982 John Deere 317
engine replacement
4 replies to this topic
#1 oldman OFFLINE
oldman
  • 11 Thanks
  • 25 posts
Posted May 21, 2013 - 07:06 PM
Today, I bought a 1982 317 John Deere tractor (C317L195153M?), I bought it very cheap.  (No, I have not had time for pictures but will ASAP). The tractor is a very good shape other than it has no engine or hydraulic pump.It has front mule drive and
deck. What type and size engine would be a good replacement and easily adapted to drive shaft. I did get the flywheel and adapter in the purchase. I would even consider trying to install a small three or four cylinder motor. I have a small front-end loader I plan installing on this tractor,
What type and size of rear wheels will fit on this tractor?
Does anyone off-hand know the bolt pattern and the needed off-set on the wheels?
All suggestions and comments are appreciated,
oldman
Edited by oldman, May 21, 2013 - 09:32 PM.
  • hamman said thank you
  • 14,863 Thanks
  • 15,511 posts
Posted May 21, 2013 - 10:02 PM
John Deere offered an Onan P218 as a direct replacement for the Ill fated KT-17 Kohler Series I, so you could go that way. Several Co. offer Honda re-powers for the 317. You could drop a Yammar or Kubota Diesel in it.
If you are going to put a loader on it, you might want to upgrade to power steering.
Good Luck !!
  • oldman said thank you
#3 oldman OFFLINE
oldman
  • 11 Thanks
  • 25 posts
Posted May 21, 2013 - 10:35 PM
Good Luck !!
I have just been reading about the power steering and I am sure no matter what engine I go with (Kuboto Diesel has a nice ring to it), I will install power steering. I am much too old to fight with the loader any more. ANy suggestions as to the easiest way to install Power Steering on 317?
Thanks for your Reply,
  • 14,863 Thanks
  • 15,511 posts
Posted May 21, 2013 - 10:45 PM
The best way is to use this column out of a 318. Here is what you want to find, but they can be found cheaper then this.
For Reference,
http://www.ebay.com/...=item589ff04891
There are other brands of equipment that also used them.
#5 oldman OFFLINE
oldman
  • 11 Thanks
  • 25 posts
Posted May 21, 2013 - 10:53 PM
For Reference,
Thanks for being so helpful. I thought that price was a little high myself.
Also tagged with one or more of these keywords: engine replacement
