I've got a 12hp kohler from a raider and a Kawasaki (14hp I think) out of a mule. They are smaller that I would want but which would pair up better with a rear end from a 520-h ?
Sent from my HTC One VX using Tapatalk 2
Which Engine?
Started by
BairleaFarm
, May 21, 2013 05:12 PM
2 replies to this topic
#1
OFFLINE
Posted May 21, 2013 - 05:12 PM
- larryd said thank you
#2
OFFLINE
Posted May 24, 2013 - 07:40 AM
The 12hp will be a direct fit and fine. The Kawy probobly can be made to work if the crank shaft is long enough and the right size
#3
OFFLINE
Posted June 02, 2013 - 06:07 AM
Never tried a 520H. My 520-8 has the 20hp Onan.
Much experience with 12hp Kohlers, that's the engine I would use 'cause I have one.
The Kohler should bolt and belt right up. Good luck with your re-powering.
