Kohler Was Sputtering!
8 replies to this topic
#1 KennyP ONLINE
  • 38,221 Thanks
  • 45,860 posts
Posted May 21, 2013 - 06:01 AM
Finally got some seat time yesterday mowing with the Ford. It would run fine for a bit, but sputter/stutter when I hit a bump. Thought possibly a bit of water in the carb bowl. As I finished up, it just died. No spark again. Pulled the sides off to check things out. Found a spot in the wire to the points that the insulation had worn off, grounding it out. So I now need to replace the wire.
Sorry for no pics, but the camera was here in Tulsa and I mowed in Collinsville. But I thought folks might want to think about this when dealing with a misfire/no start condition.
  • Texas Deere and Horse, tinbender7, HDWildBill and 2 others have said thanks
#2 boyscout862 ONLINE
  • 12,824 Thanks
  • 9,155 posts
Posted May 21, 2013 - 07:00 AM
How goes the move? I've had good results with "liquid tape". Just paint it on the wire and let it dry. Good Luck, Rick
#3 KennyP ONLINE
  • 38,221 Thanks
  • 45,860 posts
Posted May 21, 2013 - 07:08 AM
I need to look it over more closly as I think some strands are broken. "Liquid Tape" would be good if I think the wire is usable.
The move is going slowly, waiting for carpet layers in the new 'apartment' we just built.
#4 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 21, 2013 - 07:29 AM
hopefully u can fix it easily, keep us posted
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 21, 2013 - 07:57 AM
You probably should replace the wire if it's original Kenny. At 30+ years old and exposed to heat vibration and oil it could have a lot of weak spots in the insulation. You can also get a product called fusion tape. It looks like wide electrical tape but has a backing on it and is streatchier like rubber. You put it on like electrical tape and it fuses to itself and to what it's wrapped around. It makes a good easy repair where heat shrink tubing would be hard to do because you need to get the tubing over one end of the wire.
#6 KennyP ONLINE
  • 38,221 Thanks
  • 45,860 posts
Posted May 21, 2013 - 08:15 AM
The wire has a soft rubber cover, I think I had replaced it when I put new rings in. But it got wedged between the block and PTO bracket, wearing the cover off. I can take one connector off and put 'heat shrink' over that area, but that would make it rather short I'm afraid, causing more abrasion elsewhere. So I may as well remove the PTO shaft and run a new wire that will be long enough to alleviate the abrasion but not get caught up in moving parts.
#7 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted May 21, 2013 - 10:36 AM
Kenny did your bracket get home safely ?
#8 KennyP ONLINE
  • 38,221 Thanks
  • 45,860 posts
Posted May 21, 2013 - 11:33 AM
Yes it did! Sorry for not letting you know!
#9 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 21, 2013 - 01:58 PM
Sounds like a plan. If it got snagged once it will happen again if you don't change the length/routing of the wire.
