2418 Power King Rear Wheels
18 replies to this topic
#16 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted May 22, 2013 - 04:13 PM
Here are some pictures. The first one belongs to Jeff (I think), and the second I am not sure where I saved it from. You can see that there is quite a big difference in the distance between the spindle block and the top of the tire. At first, I thought it was easily a few inches, but then after looking at it maybe it really is only 5/8 of an inch.
#17 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted May 22, 2013 - 05:39 PM
I'm not sure where some of you guys are only coming up with 5/8 difference,the 24" are 2 1/2 longer than the 16" models.That is the reason they bend so much easier.
#18 mriva OFFLINE
mriva
  • 1 Thanks
  • 3 posts
Posted May 29, 2013 - 11:28 PM
I would like to let everyone know that I found a one piece 24" rim that will fit the power king 6 lug hub
The John Deere 3032E has such a rim with 11.2 tires but they are quite expensive at 303 each. I'm stil researching
to find something a little cheaper. Thanks again for everyone's input Mike in Maine
#19 Alc ONLINE
  • 7,254 Thanks
  • 7,595 posts
Posted May 30, 2013 - 05:34 AM
Here's a site that might be able to help you with an adapter  to go from 6 lug to 5
http://adaptitusa.co...ugadapters.aspx
