Snowmobile Engine On Hydraulic Transaxle
8 replies to this topic
#1 Teach OFFLINE
Teach
  • 15 Thanks
  • 12 posts
Posted May 20, 2013 - 03:06 PM
I am not 100% sure if this is the best place to post this since I am not building a dedicated pulling tractor but here it goes. I acquired a cub cadet hydraulic rear end and 440cc snowmobile engine out of an arctic cat trail cat. I am wanting to custom build a pulling tractor/snow pusher/all around pulling tool.
What I want to know is would a snowmobile engine be a adequate power source for a hydro transaxle?
Will the high rpms  of the 2cycle hurt or help the hyrdo?
I know that there are limitations to the hydro with pulling but I really want to use it for snow pushing and pulling garden equipment.
Thanks,
Teach
#2 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,334 Thanks
  • 10,293 posts
Posted May 20, 2013 - 04:50 PM
I'm glad you found our place! Welcome!
I think you would be better off using a stick shift for competition AND snow plowing. Both of those are heavy use. A hydro is great for mowing, but otherwise not.
  • Dieselcubmike and Teach have said thanks
#3 olcowhand ONLINE
  • 43,180 Thanks
  • 32,014 posts
Posted May 20, 2013 - 05:01 PM
Too high an rpm WILL damage a hydro.  I am not sure what is the redline for a hydro to spin, but I know it's well below what that 2 stroke will churn out.
  • Dieselcubmike said thank you
#4 Teach OFFLINE
Teach
  • 15 Thanks
  • 12 posts
Posted May 20, 2013 - 05:15 PM
I was afraid the rpms would be the case. As for better for pulling and snow plowing, I would agree strength wise but man a hydro is nice pushing snow.
I did find a allis 314 on CL the other day. Now I don't know anything about them but, it didn't have a motor and seemed to be gear driven. Would that make a good puller?
#5 olcowhand ONLINE
  • 43,180 Thanks
  • 32,014 posts
Posted May 20, 2013 - 05:20 PM
Not sure, but the weak link on a gear 314 may be the angle gearbox.  That model has a driveshaft off the engine that goes into a 90 degree gearbox.  the output of the gearbox changes to belt, driving the transaxle.  For pulling I think the gearbox may give problems from the severe loads, but who knows, it might hold up well.  But as you likely know, the more direct the driveline is, the less power is used up before it even gets to the ground.  That's the reason Cub Cadets are so sought after for pulling.  The driveshaft goes directly into the transaxle.  Nothing to slip except the clutch, and they can be modded to where that's no issue at all.
#6 Teach OFFLINE
Teach
  • 15 Thanks
  • 12 posts
Posted May 20, 2013 - 08:58 PM
I got to thinking this evening, I could build a really sweet drag mower out the snowmobile drive system. Maybe I should go that route instead of a puller. I don't know. I am sure I will be asking questions soon depending on what I decide.
Thank you for all your help.
Teach
#7 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted May 20, 2013 - 09:01 PM
The only way I see to do this is to have a 2to1 reduction between the motor and the Hydro trans-axle
Plus you would need a governor on the motor.
#8 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted May 20, 2013 - 09:21 PM
Daniel seems to have things patented down here :thumbs:
#9 Teach OFFLINE
Teach
  • 15 Thanks
  • 12 posts
Posted May 20, 2013 - 09:26 PM
Thank you for the idea of how to make it work but I think it may be more work than it is worth.
