Vote for Tractor of the Month
Ss12 Tranny Oil
12 replies to this topic
#1 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 19, 2013 - 09:12 PM
Hi all.  Getting my "new to me" SS12 ready to mow.  I changed the engine oil, and the trans oil.  The tranny oil was super milky.  Where is it possible for water to get into the trans?  I'm sure it must have a vent, but wow, the oil was like condensed milk.
Any thoughts?
Thanks.
H
#2 boyscout862 OFFLINE
  • 10,076 Thanks
  • 7,687 posts
Posted May 19, 2013 - 09:21 PM
You were right to drain that out. It may have leaked around the shifter. I use an old trick. When a tractor has been sitting for a while, I loosen the transmission drain plug to let any water out. The thicker oil doesn't leak by the threads. Good Luck, Rick
  • GT5k6spd said thank you
#3 MH81 ONLINE
  • 28,055 Thanks
  • 28,978 posts
Posted May 19, 2013 - 09:34 PM
If you can get hands on an old inner tube, try this.
Cut a 7-8" circle, find center and use a hole punch to make a 1/4" hole.
Take off knob, Slide rubber over the shaft and by pleating it, you can get it under the body where you don't see it.
Position it so the pucker is up, not down like a funnel and you just drastically reduced the water that can get in.
  • boyscout862, robert_p43, GT5k6spd and 1 other said thanks
#4 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 19, 2013 - 11:47 PM
Thats a great tip. I will do it in the morning.  Thanks
#5 TAHOE ONLINE
TAHOE
  • 6,604 Thanks
  • 5,029 posts
Posted May 20, 2013 - 08:33 AM
My 16/6 was very milky when I drained it, just seeped in. I think they also get hot during use and on a humid day as they cool down, they suck moisture in. Do it enough times and you develop some water in there. Gettni gready to pull and drain my ST16 rear, hopefully it's fairly clean.
#6 Guest_gravely-power_*
  • Guests
Posted May 20, 2013 - 08:44 AM
Condensation produces a lot of water.
#7 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 20, 2013 - 06:09 PM
Installed the rubber disk as per MH81.
Got to thinking about what TAHOE said.  I'm into old brit bikes.  I install a "one way" valve on the engine breather.  Not for the same reason, but it would be appropriate.
Where is the trans breather on my SS12?
#8 TAHOE OFFLINE
TAHOE
  • 6,604 Thanks
  • 5,029 posts
Posted May 21, 2013 - 10:02 AM
Don't think they have one. Unlike most cars/trucks, they do not generate enough heat/expansion to need a breather like on a car rearend. I think the suburban rears are basically sealed once you put fill plug back in.
  • redb4 said thank you
#9 MH81 ONLINE
  • 28,055 Thanks
  • 28,978 posts
Posted May 21, 2013 - 11:13 AM
:ditto:
Tahoe is right, they really don't have one in the normal sense... the shifter, etc all leak a little air and would more than handle any expansion/contraction it may need.
  • TAHOE and redb4 have said thanks
#10 redb4 ONLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 21, 2013 - 06:56 PM
I can see what you mean about a breather, makes sense.  The rubber ducky shifter disk is installed.  It will knock one possible water source out of the loop.
Thanks again
#11 MH81 OFFLINE
  • 28,055 Thanks
  • 28,978 posts
Posted May 21, 2013 - 09:32 PM
 The rubber ducky shifter disk...
:bigrofl: that's great, you gave it a name. Thanks, I needed that... :thumbs:
#12 KennyP ONLINE
  • 29,611 Thanks
  • 40,563 posts
Posted May 22, 2013 - 01:37 AM
Thanks again
Got a pic of this 'mod'?
#13 redb4 ONLINE
redb4
  • 39 Thanks
  • 61 posts
Posted May 24, 2013 - 05:55 PM
It would be hard to take a picture.  If you refer to post #3 in this tread there is a good description.
