She Came Home With Me Today! Mf10
massey 10
26 replies to this topic
#16 LYON222 OFFLINE
LYON222
  • 134 Thanks
  • 115 posts
Posted May 20, 2013 - 08:55 AM
Can't wait to see them!! Are they the older or newer style starting system?
#17 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted May 20, 2013 - 10:50 AM
1967
  • LYON222 said thank you
#18 LYON222 OFFLINE
LYON222
  • 134 Thanks
  • 115 posts
Posted May 20, 2013 - 04:40 PM
Well when I said this thing had more power than I was expecting I wasn't lying! I mowed a little grass err ummm well it was more like full height hay! We have some spots you just can't get the brush hog in… but the massey chopped it right down!
#19 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted May 20, 2013 - 05:40 PM
With enough weight and whatnot, you will have no problem moving snow with it either.
Glad you're enjoying the 10, they're great little machines.
#20 LYON222 OFFLINE
LYON222
  • 134 Thanks
  • 115 posts
Posted May 20, 2013 - 06:40 PM
It works perfect except for one thing… it doesn't seem to charge. It turned VERY weak when I got it even with a jumpstart but after a good cleaning of all the grounds it rolled over fine. Every time i go to start it t gets weaker and weaker until no go. I can't find any bad wires or what not so I'm thinking a starter/ generator rebuil is in order?
#21 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted May 20, 2013 - 06:44 PM
More likely to be the voltage regulator.
#22 LYON222 OFFLINE
LYON222
  • 134 Thanks
  • 115 posts
Posted May 20, 2013 - 07:10 PM
Thanks olcowhand! I was almost thinking that because it still cranks over good and strong.
#23 mtoney OFFLINE
mtoney
  • 947 Thanks
  • 736 posts
Posted May 20, 2013 - 07:30 PM
If you take a jumper wire and ground the "F" terminal on the starter/generator for a moment while observing a voltmeter hooked to the battery terminals, you should see the voltage rise to over 13vdc or even over 14.5.  Grounding that terminal makes the generator go "full field" or to full charge so you only want to do it for a moment.  If it does put out power, then the problem is the voltage regulator.  If not then the starter/gen has issue.  If your problem is in the VR, take the cover off and clean all the points style contacts in there and try it again.  Thats all it took to get my old Cub Cadet charging again, better than dropping $30+ on a new VR.  Good Luck.   Mike
  • Texas Deere and Horse, IamSherwood, boyscout862 and 1 other said thanks
#24 LYON222 OFFLINE
LYON222
  • 134 Thanks
  • 115 posts
Posted May 20, 2013 - 09:08 PM
Thanks for the advice mtoney, I didn't have a voltmeter on hand but I went ahead and took the VR off and cleaned all the points and contacts. It's kind of hard to tell because the amp gauge moves around a little bit but I believe it's showing + amps now. I'll make sure to let you know tommorow when I get a chance to run it around. Guess its time to install headlights!!
#25 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted May 21, 2013 - 07:15 AM
We have that problem every spring with Ryan's. it (so far has been the following)
First time, filed internal regulator contacts, cleaned ground surface (chassis bolts) locations.
Rest have all been intermittent ground at the regulator.
#26 LYON222 OFFLINE
LYON222
  • 134 Thanks
  • 115 posts
Posted May 21, 2013 - 05:53 PM
well it still isn't charging. ill have to get a meter and go from there :wallbanging:
#27 UncleWillie OFFLINE
  • 16501 Thanks
  • 9061 posts
Posted May 21, 2013 - 06:36 PM
Nice. I have a soft spot for those red machines. One day I will have one.
Also tagged with one or more of these keywords: massey 10
