Need a good seal number... please
6 replies to this topic
#1 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted October 29, 2010 - 07:44 PM
The rest of my seals came in today, but the expensive one is wrong.
Maybe someone's been through this before, (I hope).
It's the B-10 late model, bevel gearbox, right side seal... the one
that holds the ball bearing in place, and which seals against the one
inch sleeve, that rides on the the shaft, eventually belted to the trans.
It's the larger of the three in the gearbox.
The original seal is a Victor #60254, with patten # 2240332.
What was sent to me was a CR seal, # 542016, with a steel ring that is
to be installed behind it to hold the bearing in place... but not my bearing.
The BGB # is 154062, but now see there are different seal sizes depending on
which tractor or model the BGB finds itself in.
So... help is needed... again
thanks
walt
#2 MH81 ONLINE
  • 28,003 Thanks
  • 28,948 posts
Posted October 29, 2010 - 08:35 PM
mIGHT WANT TO TRY HERE: Simplicity-Allis Models list
They have some references by exploded view. Might give you a current # to cross from.
  • justwalt said thank you
#3 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted October 30, 2010 - 10:13 AM
These gearboxes were used for the B-10's through the B-212's.
There must be thousands out there. Don't know if my BGB was
swapped out once or twice sometime in the past 44 years, but maybe.
I suspect that the manufacturer installed different seals of
different sizes due to availability... just as is done today.
I'll check with a bearing company that I know in Scranton...
they know it all.. and they don't use computers either.
thanks MH81
walt
#4 Guest_Big Bill_*
Guest_Big Bill_*
  • Guests
Posted October 31, 2010 - 01:02 PM
Allied Bearing, largest in the world, if they don't have it, they make it
#5 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted October 31, 2010 - 02:20 PM
Thanks Bill, I'll check them out tonight...
I did find a cross from (Victor # 60254) to (Timken # 471733).
Walt
#6 NUTNDUN OFFLINE
  • 10,269 Thanks
Posted October 31, 2010 - 06:45 PM
I used to pickup rolled steel from Timken in Ohio. Hope you find what ya need Walt.
#7 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted November 02, 2010 - 08:01 PM
Well, the Timken number is good... except for the thickness.
I can get one that is 1/4" thick instead of 0.47-something" thick.
To get the exact seal, at the right thickness, I need to buy 250 of them.
So, I'll have to make a spacer to fit behind the seal to ride against the ball bearing.
Hey... a wheel bearing race might work... looks like machine shop work. To be continued...
Walt
