Stanley, Our Lawn Tractor
49 replies to this topic
#46 Earl OFFLINE
Earl
  • 76 Thanks
  • 120 posts
Posted March 21, 2015 - 06:22 PM
What's the proper way to set it? I've been using a write up where you go 1/4" down from TDC and set it at (I).004/(E).006. #2 cylinder seems fine. I've not readjusted it today at all. It checked right on spec.
#1 started out too tight, it would start easy but pop through the carb when running at any rpm. I reset it to spec, then the starter wouldn't turn the engine. I loosened it a tick, starter barely turned it cold but wouldn't restart it hot. Have I lost the compression relief lobe on the cam or something?
#47 Earl OFFLINE
Earl
  • 76 Thanks
  • 120 posts
Posted March 22, 2015 - 11:03 AM
Out of shear audacity, I swapped on the original starter this morning. Cranks over fine now. We'll see how long this lasts... It still seemed a bit flooded and started without the choke on but didn't blow raw gas onto the ground when it started.
#48 Earl OFFLINE
Earl
  • 76 Thanks
  • 120 posts
Posted April 17, 2015 - 01:10 PM
Well, hit the key today and he roared to life in fine style. Put the deck on and managed the first mow of the season without mishap. Looks like we finally got it!
#49 KennyP OFFLINE
  • 35,122 Thanks
  • 44,131 posts
Posted April 17, 2015 - 07:04 PM
Glad he is earning his keep!
#50 Earl OFFLINE
Earl
  • 76 Thanks
  • 120 posts
Posted April 17, 2015 - 08:10 PM
Its goods so far. There was a random popping from the frame maybe. Gonna have to look it over this week. Tire chains were awesome though. Now I just need to hunt up some wheel weights for it.
  • UncleWillie said thank you
