Overloaded Speedex!
5 replies to this topic
#1 glgrumpy OFFLINE
  • 8,742 Thanks
  • 7,978 posts
Posted May 17, 2013 - 08:36 PM
Been kinda looking at this tractor at show. It WAS a speedex  at one time. Has orig frame and drive axle and that's about it. Has a big twin engine, and a pump to run the drive motor which looks kinda like a Case driveline. Really BIG chains to rear sprockets, two of them actually. Big hydraulic valve and pleny of hoses and ends. Not sure what purpose really was, maybe a portable power unit?  "Wanted $300 for it.
  • hamman and boyscout862 have said thanks
#2 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted May 17, 2013 - 10:26 PM
It's different thats for sure! Is it me or did that thing have a serious issue in the drive line? It looks like the sprocket on the right is bent and the c-channel the pillow block is mounted to looks bent and twisted? I think they might not have put enough thought into the drive train  when they put the bigger engine on it.
#3 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted May 17, 2013 - 11:21 PM
With all those hoses it almost looks like he could run a front loader on it and anything else setup for for hydraulics! And for 300$ that is an awesome deal
#4 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted May 18, 2013 - 05:25 AM
$300 is a deal on the parts alone.
#5 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted May 18, 2013 - 06:39 AM
He had $300 at least in it with all those modifications.
Ben W.
#6 glgrumpy OFFLINE
  • 8,742 Thanks
  • 7,978 posts
Posted May 18, 2013 - 09:00 PM
Don't think that little Speedex frame could take too much more weight! Those things are only about 3/4" x 2" bar stock in the frames. Maybe 1" thick at most. Light front ends too. The parts might be worth some if you had a use for them. Didn't sell I don't think. Guy was gone today like most of the sellers. Last day is NO good at this swap!
