Deck Wheels
4 replies to this topic
#1 Walkinman1 OFFLINE
Walkinman1
  • 769 Thanks
  • 586 posts
Posted May 16, 2013 - 01:47 PM
Trying to find some wheels to replace the severely worn ones on the deck that came with my 120. They don't need to be a factory match, just something functional (I have a factory set on my other deck in pretty good shape but I'd like to preserve them). I searched everywhere I can find online and I can't find a hub/bearing diameter that will fit.
I need wheels that are between 6" and 7", preferably 7", ball bearing. The catch is that the hub can't be over 1 5/8" thick and it needs to have a 5/8" bore so the special pin that Ford used will fit thru and lock into the deck properly. Any tips on where to look?
#2 boyscout862 OFFLINE
  • 13,439 Thanks
  • 9,385 posts
Posted May 16, 2013 - 04:37 PM
Try our sponsors. Another possibility is NAPA, they have a small engine and mower catalog that has lots of parts by size as well as brand. Good Luck, Rick
#3 Walkinman1 OFFLINE
Walkinman1
  • 769 Thanks
  • 586 posts
Posted May 16, 2013 - 04:44 PM
Thanks for the tip, after I even struck out at McMaster-Carr I figured it was nearly hopeless and that I'd have to have the mounting pins milled down or just rig something but I'd rather not have to resort to that...
#4 Walkinman1 OFFLINE
Walkinman1
  • 769 Thanks
  • 586 posts
Posted May 19, 2013 - 03:22 PM
Well I solved my problem quite neatly and inexpensively. Since I couldn't find wheels to fit the quick adjust pins and didn't want to modify anything I decided to make pins that fit readily available wheels...one half inch bolt and a little time you can see what I wound up with... Here's a comparison pic between the original and the new one: uploadfromtaptalk1368994873071.jpg
Here's the finished product: uploadfromtaptalk1368994920470.jpg
#5 KennyP ONLINE
  • 40,124 Thanks
  • 46,764 posts
Posted May 19, 2013 - 06:35 PM
Glad you got it figured out! Looks good!
