What Wheel Weights Should I Use?
9 replies to this topic
#1 skinnison OFFLINE
skinnison
  • 7 Thanks
  • 10 posts
Posted May 16, 2013 - 08:54 AM
Here is a pic of my Craftsman GT3000 rear wheel. Are the square holes intended for mounting wheel weights? I was hoping to mount some without having to drill.
Thank you
#2 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted May 16, 2013 - 09:04 AM
Yes, that is what those are for. If you can get long carriage bolts, then you don't need a wrench for the inside!
  • Cvans and skinnison have said thanks
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 16, 2013 - 09:55 AM
The holes should be the standard spacing for a 12" wheel so any 12" weight has a good chance of fitting.
#4 CADplans OFFLINE
CADplans
  • 219 Thanks
  • 213 posts
Posted May 16, 2013 - 10:02 AM
AND, you only need 2 bolts per weight.
Most people use the extra 2 holes to bolt ANOTHER set of weights to the first set of weights.
  • Cvans, boyscout862 and skinnison have said thanks
#5 Cvans ONLINE
  • 6,648 Thanks
  • 6,129 posts
Posted May 16, 2013 - 10:18 AM
I have several different types of wheel weights on my tractors and the information given here is spot on.
You can also add fluid to your rear tires.
  • skinnison said thank you
#6 Sandburr OFFLINE
Sandburr
  • 35 Thanks
  • 46 posts
Posted May 16, 2013 - 12:22 PM
Like wise with everyone else.
1984 316
  • boyscout862 and skinnison have said thanks
#7 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 16, 2013 - 02:16 PM
u could use any wheel weight u want. some people use steel donuts
#8 skinnison OFFLINE
skinnison
  • 7 Thanks
  • 10 posts
Posted May 20, 2013 - 06:11 AM
Got a set of Sears and Roebuck 55 pound weights off Craigslist for $50. They fit perfect, although I had to put the carriage bolt in from behind so when I tightened it the square part of the bolt fit into the square hole in the wheel, keeping it from spinning. I guess I have to just be careful not to bang up the ends of the bolts that are sticking out past the weights. If I screw them up then taking off the nut to remove the weights will be a problem.
#9 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted May 20, 2013 - 06:26 AM
I still have the bolts sticking out on the weights I put on. Need to cut them off as they aren't good on the shins!
#10 skinnison OFFLINE
skinnison
  • 7 Thanks
  • 10 posts
Posted May 21, 2013 - 05:29 AM
Yup, was thinking that....
