Walbro Whg Throttle Shaft
4 replies to this topic
#1 mrchrrh OFFLINE
mrchrrh
  • 3 posts
Posted May 15, 2013 - 10:43 PM
I have a 1983 deere 314 with kohler k321aqs and a walbro whg carb.  the throttle shaft is loose and worn.  I have seen throttle shaft repair kits and found there are different ones. but I cant seem to find the correct one for my carb.  does anyone have any ideas?
Thank You,
Marc
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,303 Thanks
  • 9,781 posts
Posted May 16, 2013 - 06:46 AM
What is different about your carb?
#3 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,460 Thanks
  • 5,767 posts
Posted May 16, 2013 - 06:48 AM
What carb # is stamped on the carb-to-engine flange or bowl flange?  Look that # up..
#4 Trav1s ONLINE
Trav1s
  • 3,309 Thanks
  • 4,364 posts
Posted May 16, 2013 - 07:42 AM
I will check my service manual and see if I can find anything for it.  Have you tried the Kohler K series service manual available from the Kohler website?
#5 mrchrrh OFFLINE
mrchrrh
  • 3 posts
Posted May 16, 2013 - 03:14 PM
i am not sure if anything is different with my carb.  But there are three different kits and I figure there is one made for the whg carb.  I dont know which one it is.  I have looked in service manual. It tells how to install bushing but it doesnt tell me which kit.  or at least I didnt see it. there are several numbers on carb flange and I am not sure what the numbers mean.  I have not seen anything that explains the numbers.
Thank you for the help.
Marc
