Cub Cadet Original Stalling
9 replies to this topic
#1 mikes47jeep OFFLINE
mikes47jeep
  • 60 Thanks
  • 22 posts
Posted May 15, 2013 - 07:59 PM
hi all
i have a cub cadet original with the stock 7hp Kohler
the issue i'm having is it will stall when i advance the throttle, unless i do it very very slowly
bad condensor? poorly adjusted points?
any ideas
thanks
Mike
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted May 15, 2013 - 08:03 PM
Float level.
#3 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted May 15, 2013 - 08:28 PM
Have you tried adjusting the high speed needle on the carb? If that doesn't help then a carb rebuild may be in order.
But I would make sure your points are clean and gapped correctly, and make sure the plug looks good. before a carb rebuild.
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted May 15, 2013 - 08:31 PM
Float level.
That could be, but the problem (if it is carburetor) is that it is running too lean.  Does it start well?
It could very well be that the points are adjusted wrong, too.
Ben W.
#5 mikes47jeep OFFLINE
mikes47jeep
  • 60 Thanks
  • 22 posts
Posted May 15, 2013 - 09:27 PM
starts fairly easy, carb is a fresh rebuild, ill double check the points
#6 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted May 15, 2013 - 10:41 PM
I would give it a little more open on the high speed jet and check the points.
#7 IlovemyCub OFFLINE
IlovemyCub
  • 172 Thanks
  • 204 posts
Posted May 16, 2013 - 05:45 AM
I would re-adjust the carb, and try gapping the points to the correct gap. Or just buy new points and condencer. Good luck. Ian
#8 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 16, 2013 - 08:43 AM
try seting the carb to factory specs and go from there
#9 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted May 16, 2013 - 11:28 AM
Since it does rev up, sounds like a carb issue (clean, float level, etc.)
Try adding a small amount of choke before trying to rev up - help identify if it's a gas supply issue.
A common problem with the K161 internal coil is a partial short to ground.  While not running, remove the sparkplug wire and check the resistance between the plug wire and ground.  Should be about 7K ohms (going by memory - correct me if I'm wrong).
#10 Gfann OFFLINE
Gfann
  • 194 Thanks
  • 228 posts
Posted May 17, 2013 - 08:40 PM
Sounds every one has the right idea. Carb adjustment would be the first easy step. Seems like you are possible getting to much fuel. Does the emgine start fine after the stall or does it need to set for a minute? If its a excessive fuel issue then the engine should flood and not start. If it starts right right up then it could very well be the points. Was this an issue that just suddenly happened? I'm jealous I want a cub original.
