What Would Y'all Do?
12 replies to this topic
#1 Walkinman1 OFFLINE
Walkinman1
  • 770 Thanks
  • 589 posts
Posted May 15, 2013 - 06:16 PM
I was just given this (for free) by a friend of mine because he doesn't wanna mess with it. I'm told it was run out of oil. I haven't torn into it yet but I DO know that the engine doesn't turn over, at all. He said he broke it free and turned it over, accompanied by a bad clanking sound so I'm just assuming it's toast. I have a few options, fix (engine swap or rebuild) and sell (I don't want it) or just save what I want for parts and scrap the rest. I do know a couple of people who would buy it from me if I get it fixed cheap enough or I can always use parts for things, seat, battery, flotation tires for the yard trailer after some mods, spare transaxle for when I finally blow up the one in my older craftsman, etc. What do you guys think?
  • boyscout862, oldedeeres, larryd and 1 other said thanks
#2 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,598 Thanks
  • 2,909 posts
Posted May 15, 2013 - 06:22 PM
Actually I would check to see how bad it is. Could be as simple as buying a shortblock and getting it running and keeping it as a spare. Or possibly rebuilding the motor in it if it is not cracked or have a hole in it. Looks good. Good luck.
  • New.Canadian.DB.Owner, oldedeeres and larryd have said thanks
#3 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,112 Thanks
  • 10,183 posts
Posted May 15, 2013 - 06:45 PM
My own experience is, as soon as I get rid of it an engine will come along.
  • Alc, boyscout862, oldedeeres and 1 other said thanks
#4 Walkinman1 OFFLINE
Walkinman1
  • 770 Thanks
  • 589 posts
Posted May 15, 2013 - 07:05 PM
Maybe someone will offer up an engine for me to use/cannibalize  :dancingbanana:
  • larryd said thank you
#5 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted May 15, 2013 - 07:49 PM
FWIW, my motto is "Always have a spare."  As an example, I just sold my Husqvarna LT125 because I also have a Poulan and a Yardman.  This weekend I had enough non-rain time to mow the lawn so I dug out the Yardman.  First turn of the key, it locked up solid.  Turned out the starter gear broke & was getting jammed into the ring gear.  No problem I have a spare starter, except it is on the Husqvarna.  Fortunately, the Poulan started fine.  Always have a spare.  Having money from the sale of spare parts doesn't help on Sunday of a long weekend.
  • boyscout862, twostep, oldedeeres and 1 other said thanks
#6 bja105 OFFLINE
bja105
  • 196 Thanks
  • 191 posts
Posted May 15, 2013 - 07:53 PM
You can put an add on Craigslist.  Someone might buy it for the transaxle, then the rest can clutter up their yard instead of yours.  Beside my garage is starting to look like Sanford and Sons with all the junk I saved for the 'good' parts.
  • boyscout862 and larryd have said thanks
#7 glgrumpy OFFLINE
  • 8,815 Thanks
  • 8,014 posts
Posted May 15, 2013 - 08:25 PM
Looks nice enough to Me to fix it. What engine, just a single?  Going to big shows can help you find one that fits would think. OR, just get manual for engine and teardown and look over the parts and see what it might need. Buy a kit and have bored and valve job if needed and reassemble. Parting don't work on a less popular brand. You'll sell a few major parts, have the rest around long time, and then YOU won't be able to fix if wanted cause all the major stuff is gone and hard to find again.
#8 Walkinman1 OFFLINE
Walkinman1
  • 770 Thanks
  • 589 posts
Posted May 15, 2013 - 08:55 PM
It's just a newer 16 HP Briggs single, haven't bothered to get numbers off of it or anything yet, the 13 HP on my other, older craftsman looks identical aside from some plastic shrouds. Guess I'll see what's actually broken and go from there. Maybe it won't need all that much...then again if it was run out of oil who knows...
#9 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 871 Thanks
  • 722 posts
Posted May 15, 2013 - 09:35 PM
never look a gift horse in the mouth.. About the time you get rid of it, you'll need or want or be able to sell it.
#10 oldedeeres OFFLINE
oldedeeres
  • 10,483 Thanks
  • 5,093 posts
Posted May 16, 2013 - 01:54 AM
I'm with Grumpy on this one. It's a sweet looking little machine, isn't eating anything but space while you check it out and then possibly wait for the parts it needs to show up. You know they will, sooner or later  lol.
#11 Alc ONLINE
  • 7,226 Thanks
  • 7,579 posts
Posted May 16, 2013 - 06:02 AM
I hear of quite a few newer tractors having trans axles go bad , maybe you'll find one of those with a good engine ,good luck !
#12 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted May 16, 2013 - 02:18 PM
put a new motor on it and sell it at the swap meet
  • twostep said thank you
#13 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted May 17, 2013 - 12:49 PM
X2
I've found that the engines on these cheap little mowers usually outlast the decks and front wheel bushings... that being said, you shouldn't have a problem finding an engine for it... I've actually got a great running 13hp briggs sitting on the shelf... waiting for a mower like this to come along.
The important question; what condition is the deck/spindles in? if they are good then put a $75 engine on it and sell it for a couple hundred dollars.
