Part Wanted Update
4 replies to this topic
#1 jonsteffen OFFLINE
jonsteffen
  • 4 Thanks
  • 98 posts
Posted May 14, 2013 - 09:53 PM
I am looking for a throttle shaft like the one on this carb I do have kohler parts to trade or I can find other engine parts to trade I have circled the part I need it is a common part on the newer carbs
#2 jonsteffen OFFLINE
jonsteffen
  • 4 Thanks
  • 98 posts
Posted May 14, 2013 - 10:00 PM
this is the linkage that that it hooks to
#3 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted May 14, 2013 - 10:58 PM
what is the matter with your Throttle Shaft?
just loose or wobles in the carb?
if it is loose or wobles in the carb - it is a easy fix.  I have fixed over 10 carbs.
this is how I do it
first remove the 2 brass screws from the throttle shaft
removing the 2 screws only make a 1/4 turn then back off 1/8 turn until the screw comes out.
out of the 10+ carbs I have only broken 2 screws
if you do brake a screw in the throttle shaft - just file it down so you can remove the throttle shaft from the carb
then I use my demal tool and cut a small cut across the screw to just fix small screw driver into the slot - then you can remove the broken screw
I go to Ace Hardware and get 2 bonze washers - 1/4" id and 7/16" od and 2 stainless machine screws to fit the throttle shaft and 2 stainless lock washers
clean the carb
I put a very little gasket sealer in the hole before I put the washer in - help seal them
with a 1/4" bolt  over 1" long I put the washers on the bolt and put the 1/4" bolt into the throttle shaft hole and tap lightly until the washers are level with the top of the carb
clean off any gasket sealer
now you can put in the throttle shaft in the carb and put the butterfly on with the 2 screws with the lock washers
I use the blue Locktite on the 2 screws - helps a lot
you do not a screw on top of the piston - bad news if it does
My first one I did was over 15 years ago and the screws are still there and tight
see the following link http://gardentractor...om/carbfuel.htm
scroll down to the Bronze Throttle Shaft Bushing
for more info about it
I hope this helps you
good luck
  • Bud W, Moosetales and LilysDad have said thanks
#4 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,169 posts
Posted May 15, 2013 - 09:11 AM
If you have the number of the carb you can get a shaft rebuild kit for it from kohler.
#5 jonsteffen OFFLINE
jonsteffen
  • 4 Thanks
  • 98 posts
Posted May 15, 2013 - 10:17 PM
the one I got is busted and I have looked at replacement on ebay and they are not like this
