Starting To Multiply.
20 replies to this topic
#1 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted May 14, 2013 - 09:37 PM
Well i just brought home my first bolens 2 weeks ago. I have been searching craigslist for a deck but people around here are nuts 200-400 when all i wanted was the spindle. So this poped up on craigslist for a steal it's a G10. I paid 200 but for the mower deck wheel weights and came with a rough snow plow i think i did alright.
It has a 10HP Brigs&Stratton engine and rodents have eaten the spark plug wire anyone know where to get a magneto for this thing or can i just replace the plug wire?
Edited by JohnWR, May 14, 2013 - 09:38 PM.
  • OldBuzzard, sacsr, boyscout862 and 3 others have said thanks
#2 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted May 14, 2013 - 09:52 PM
John, nice looking g10. And it sounds as if you got yourself a good deal.
BTW, those Briggs are infamous for rodent hotels... I think it's the way the tin is, but it's weird.
As for the spark plug wire, do you have a pic of the damage done? You may be able to remove the wire from the coil, splice and silicone, IDK...
#3 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted May 14, 2013 - 10:00 PM
Yea i have had a lot of issues on newer B&S motors that were on the EX inlaws trail mower without mothballs come winter they ate the plug wire. Tomorrow im going to head up to my dads to rip the cover off and see the dammage but it spins over with the starter carb needs a rebuild.
#4 boyscout862 ONLINE
  • 15260 Thanks
  • 10023 posts
Posted May 14, 2013 - 10:58 PM
Congrats on a good score. I've had some success with liquid electrical insulation. Paint on several coats and they run. Good Luck, Rick
Edited by boyscout862, May 14, 2013 - 10:59 PM.
#5 Newpaws493 OFFLINE
Newpaws493
  • 1390 Thanks
  • 1818 posts
Posted May 14, 2013 - 10:59 PM
Two weeks huh? 52 weeks in a year, think of the possibilities :rolling: Congrats! looks like a nice package deal.  :thumbs:
  • Huskyfan said thank you
#6 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted May 15, 2013 - 02:38 AM
Danged nice G19 there! Those wheel weights are going for $100.00+ on eBay, and I see that it even has the original muffler.  BTW, that's a 1977
#7 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted May 15, 2013 - 05:11 AM
That was my thinking in my area these wheels weights would go for 150+. i was after the newer styly mower deck setup with wheels myself since the 42" one i have with out scalps the lawn to much and i hate scalping with a passion.
The way i look at it is like this
wheel weights-100
mower deck setup with all brackets needed to swap to the older tube frame-100
so i got the tractor and very rough snow plow fo free.
#8 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 15, 2013 - 05:31 AM
Congrats on the New Bolens!
#9 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted May 15, 2013 - 06:21 AM
That's one sharp tractor.
Ben W.
#10 MrChic OFFLINE
MrChic
  • 4 Thanks
  • 15 posts
Posted May 15, 2013 - 06:01 PM
Before you know it 2 becomes 10 and you are on your way to a dozen. Nice tractor, congrats.
#11 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted May 15, 2013 - 08:02 PM
Ok was able to gwt up to my dads tonight and get the front cover taken off the Briggs motor and teh mice were kind enough to leave me enough wire so that tomorrow i can solder on a new spark plug wire.
I also tore off the mower deck and started investigating that. The deck was very hard to turn after taking the cover off it was just jammed with dirt took a look at the gears and they are mint and the fluid was clean.
Here is the deck serial number anyone know all hand what size belt to pick up at napa and what type of blades can be made to work i need something that helps get the grass out quicker my grass is stupid thick.
404303dd-25fd-471a-96fe-993d4c88ebcb_zps
#12 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted May 16, 2013 - 05:07 AM
Ok so i found the belt size it's 1/2"X75" now my question is my tractor supply says they dont stock this size but stock 76" long can i use this belt ot should i just wait?
#13 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 16, 2013 - 06:14 AM
I'm thinking even though there is a spring to take up slack, that it still would be too long.
Have you tried searching the part number online?
I'd get a kevlar belt if possible
#14 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted May 16, 2013 - 04:25 PM
Your still safe this is multiply V
Edited by wilberj, May 16, 2013 - 04:25 PM.
#15 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted May 16, 2013 - 08:29 PM
I called my local napa and they ordered me in one for tomorrow.
So some good news it runs and not half bad a little smoke at first but that was from teh WB40 i sprayed the cylinder with still leaking fuel from the carb so i need to clean it.
Time for my next issue i have no brake or clutch it seems. The brake pedal has no spring to it and someones getto fix was to add a return spring not fix the issue. Also the brake pads are worn to nothing so ill need to replace those.
The clutch has me a little baffled if i step on the pedal and stop the drive shaft with my foot i can change gears just fine does this mean the clutch is ok?
