Spark Plug Gap
3 replies to this topic
#1 artbuc OFFLINE
artbuc
  • 72 Thanks
  • 158 posts
Posted May 14, 2013 - 12:40 PM
The Kohler M18 in my Gravely 18-H (rebadged Ariens GT 18) calls for Champ RV15YC plugs gapped to .025". Discovered they have been replaced with a wide gap RV15YC4 plug apparently required by Big Brother to meet CA emissions standards. The new plug calls for a .042 - .048 gap. Should I re-gap the RV15YC4's to .025? Thanks.
#2 JDBrian OFFLINE
  • 9,596 Thanks
Posted May 14, 2013 - 02:48 PM
Does the Kohler service manual give any info. on this issue. You should be able to down load the manual from the Kohler site if you don't have it already.
#3 artbuc OFFLINE
artbuc
  • 72 Thanks
  • 158 posts
Posted May 14, 2013 - 03:49 PM
No, I have the Service Manual. The "4" plug is a fairly recent change. I am going to go with a RV17YC plug which I can get locally. In fact, some references specify the 17 heat range for M18 and I have read that Kohler made this change after the original Service Manual was published.
Edit: I just looked at the downloaded Owner's and Service Manual from the Kohler site. Both specify the RV17YC plug with a 0.35" gap. Guess my Service Manual is an earlier revision. Thanks a lot for the tip on the downloads.
Edited by artbuc, May 14, 2013 - 03:57 PM.
  • MH81 and boyscout862 have said thanks
#4 Piddler2 OFFLINE
Piddler2
  • 3 Thanks
  • 8 posts
Posted June 16, 2017 - 12:02 PM
Miller's Web site has some good info about flat head plug gapping and why
  • LilysDad said thank you
