Bush Hog Serial Number List- Need Your Bush Hog Gt Information
177 replies to this topic
#61 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 16, 2013 - 09:37 AM
And that's interesting because I own D4-10 S#8758  Selma Plate Wisconsin S10D S#426210. I'll message him asking for the info on the engine plate.
#62 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 16, 2013 - 09:42 AM
I always figured that they were loaded in a semi by what was sitting on the lot at that time to go from dealer to dealer. RI to TX is a bit of a drive for one. Unless someone moved across country and brought it with them.
#63 Texas Deere and Horse OFFLINE
  • 14,815 Thanks
  • 15,502 posts
Posted October 16, 2013 - 10:03 AM
D4-10 on Ebay S# 8756
http://www.ebay.com/...utorefresh=true
I posted it in the Ebay forum and also sent him an offer- a lot lower then what he's asking. :( :(
#64 Texas Deere and Horse OFFLINE
  • 14,815 Thanks
  • 15,502 posts
Posted October 16, 2013 - 02:41 PM
Scott and Peter, The D4-10 in N.E.-TEXAS is
D4-10
Selma Ks.
Serial #8756
Wisconsin  TR-10D
Engine Serial #4349057
#65 Texas Deere and Horse OFFLINE
  • 14,815 Thanks
  • 15,502 posts
Posted October 22, 2013 - 12:51 PM
Scott, Do you have a complete list somewhere with engine make and models? A spread sheet maybe?  I am to see if we can figure out when what engines were used on the D4-10s.
#66 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted October 22, 2013 - 08:28 PM
I don't have a complete list- I have it hand written on a sheet most of it- other info saved by cutting nd pasting info- I will get it on a spread sheet at some point. Just got a lot going on right now.
I only know of three motors on the D4-10: Wisconsin TRA-10D, Tecumseh HH100, and most likely the TR-10D- but I have seen very few TR-10D's in them.
#67 Texas Deere and Horse OFFLINE
  • 14,815 Thanks
  • 15,502 posts
Posted October 22, 2013 - 10:07 PM
Scott, The reason I was asking is that I need an engine for the one up in north east TX. and I have the engine in the ones I brought back from MO.. Serial # 8756 has a bad TR-10D and the parts tractor #9397 has a TRA-10D that is a good engine. do you know when the TRD's started being put in?
#68 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted October 23, 2013 - 06:18 AM
Brian unfortunately I have info that just says "10hp Wisconsin" on a good bit of the ones I have collected. I may be wrong about one thing, Titus has a D4-10 that he is showing with a S10-D motor in it....need to verify that. That is the only S10-D I have seen at this point.
I know I have seen some early D4-10's with TRA-10D motors (8000 numbered tractors) if that helps.
Burl has one that was 8351 with a TR-10D motor in it. Just not enough info to call it a pattern, but maybe they did start out with TR-10D and then moved to TRA-10.
I looked at all my versions of D4-10 manuals- they all list the TRA-10D as the motor.
Edited by sacsr, October 23, 2013 - 06:30 AM.
#69 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted October 23, 2013 - 08:47 AM
Both my 67's had TR10D.  My parts tractor had a TRA10D, and it was a 68???
#70 Texas Deere and Horse OFFLINE
  • 14,815 Thanks
  • 15,502 posts
Posted October 23, 2013 - 09:35 AM
The one I just bought off Ebay up in N E Texas has a Has the TR-10D in it and it's Serial #8756. That's why I was asking.
  • sacsr said thank you
#71 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted October 23, 2013 - 10:19 PM
I will try to see when the earliest TRA-10D motor and serial number are in the list.
#72 LPBolens OFFLINE
LPBolens
  • 1,415 Thanks
  • 971 posts
Posted October 28, 2013 - 05:18 PM
These may be duplicates of numbers you already have in the list, especially if you got some of your info from MTF, but here goes:
D4-7 S# 7512 Wisconsin S7D Selma plate
D4-10 S# 9746 no engine/parts tractor Selma plate
D4-12 S# 283 Tecumseh HH-120 Galesburg plate
  • Texas Deere and Horse and sacsr have said thanks
#73 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 28, 2013 - 05:35 PM
Hey alright!! Another D4-12!
#74 Texas Deere and Horse OFFLINE
  • 14,815 Thanks
  • 15,502 posts
Posted October 28, 2013 - 08:11 PM
Doug & Peter, can you check your frame for the cutout in it to allow the oil pan to fit the frame? Here's thread I showed Y'all mine in.
http://gardentractor...4-10-and-d4-12/
#75 LPBolens OFFLINE
LPBolens
  • 1,415 Thanks
  • 971 posts
Posted October 28, 2013 - 10:05 PM
Brian, my D4-12 does have the cutout in it. It looks just like the pics you posted, where they cut out a space in the frame and welded in a dog-leg piece to allow for room for the oil pan.
