Kubota Motor Info Needed
4 replies to this topic
#1 farmer john OFFLINE
farmer john
  • 1,830 Thanks
  • 924 posts
Posted May 13, 2013 - 08:51 PM
hi guys, about 6 months ago i found a yard with lots of kubota engines and stuff, all i could do was look through the fence and dream about buying the parts i wanted, so every time i was in the area i would stop in to see if anyone was around, well finally i found someone there, she said she spends alot of her time in japan and all the tractors are from there, i have a b6100h with bad compression, she had 3 that looked like my 1980s 3 cylinder diesel, but do they ever look different laid out on the ground with no tires body work around them, are there any block numbers on these or did kubota only have one 3 cylinder diesel, she said they all ran well and i can come and do a compression test on them, i think the price is great at $500 complete including the starter, she also has a loader for $700,
#2 boyscout862 ONLINE
  • 13,552 Thanks
  • 9,427 posts
Posted May 13, 2013 - 09:17 PM
That sounds pretty good. Good Luck, Rick
  • farmer john said thank you
#3 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted May 14, 2013 - 06:23 AM
I think old Kubota engines have a model number, although I can't remember exactly where it is.  Something in me says around the injector, maybe.
Someone else chime in if I'm wrong.  I could be confusing the new motors with the old.
Ben W.
#4 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,807 Thanks
  • 4,302 posts
Posted May 14, 2013 - 07:46 AM
Hi John,
here's a Link to the german KUBOTA-site (in englisch of course). I think here you can find some infos - good luck and you know  ildeere.gif
#5 cumminsmannow OFFLINE
cumminsmannow
  • 100 Thanks
  • 294 posts
Posted May 14, 2013 - 11:29 AM
The engine serial numbers are pretty much always on the block just below the injection pump.
