100 Hrs On The 1500 Ford
2 replies to this topic
#1 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 13, 2013 - 07:08 PM
Took a week of vacation and today graded where the dozer took out the fence, ran the landscape rake over it too. So the rough grading is done until they get the fence in so I can sow grass.
Mowed 1/2 the pasture raked down the garden (I had run the middlebuster through it again to dry it out enough I can till tomorrow.
When I was coming back to the house I noticed it had 554 hrs, so i have put 100 hrs on it since I got it in September
I have lost track of how much fuel i have used but it sips fuel. I put the first qt of oil in it today, and I do not consider that using oil. I will try to get it changed this week.
No Problems whatsoever
Correction 664 hrs, it had 551 when I bought it.
Edited by JD DANNELS, May 13, 2013 - 08:31 PM.
#2 olcowhand ONLINE
  • 40,365 Thanks
  • 31,176 posts
Posted May 13, 2013 - 07:51 PM
No, not enough oil usage to be any concern at all.  Even the best diesel engines use some oil.  In auto terms, that 100 hours would convert to 6 or 7 thousand miles!
#3 lyall ONLINE
lyall
  • 2,020 Thanks
  • 1,525 posts
Posted May 13, 2013 - 08:07 PM
glad you are happen with your Ford 1500
sound like you are going to keep it for a while
it sure sounds  like it is able to do the the work you want it to do
