David Bradley With Sickle Mower
11 replies to this topic
#1 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted May 12, 2013 - 08:07 PM
  • MH81, js5020 and New.Canadian.DB.Owner have said thanks
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted May 12, 2013 - 08:13 PM
Yours works much better than ours. Still, they make you take big boy steps tho don't they?
  • VSTROM803 said thank you
#3 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted May 13, 2013 - 03:23 AM
I'm still working on mine. I will have to adjust the cutter bar some.
#4 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted May 13, 2013 - 03:52 AM
I'm interested to see how your new knife sections work out. Where did you purchase them?
  • Amigatec said thank you
#5 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted May 13, 2013 - 04:22 AM
I found them on eBay. I used bolts and nuts and the nuts are to high. I plan to weld a bead on the bottom of the clips to keep them from hitting the nuts.
#6 Alc ONLINE
  • 7,239 Thanks
  • 7,584 posts
Posted May 13, 2013 - 07:11 AM
Thanks for posting the video  , I've been trying to get the sickle bar working correctly on the DB 600 , but even though  it's cutting better it still seems to shake too much, I might have to figure a better repair for the one that was made where the pitman arm pivots the knife section . Right now the instead of a bolt going through the square drive someone welded a 3/8" bolt from the knife section up  and the little square drive is missing, so a large nut is in it's place ,washer with 3/8"locknut ,maybe that's what's causing the shake ? Too much play
#7 js5020 OFFLINE
js5020
  • 711 Thanks
  • 807 posts
Posted May 19, 2013 - 10:39 PM
Nice working machine!  I like seeing these old machines still earning their keep.
I maybe a bit late but if the hole spacing on your knife is 3" knives can be found at TSC,,,, I redid my Gravely cutterbar a year or so ago and replaced all the knives and switched from old rivets to bolts, replaced the wear strips and used their universal knife clips so the nuts clear.  Gotta love new parts, I can now cut acres without clogging,,, it had gotten to the point that I wondered why they made such a cursed attachment.
  • Amigatec and VSTROM803 have said thanks
#8 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted May 23, 2013 - 08:42 PM
How about the bushing at the bottom that the arm pivots on? I have another sickle mower that has a lot of play there and makes a terrible racket.
#9 Alc ONLINE
  • 7,239 Thanks
  • 7,584 posts
Posted May 23, 2013 - 08:56 PM
I'll have to check the bushings in that pivot tube (  might not be correct name  lol )  I can put the best parts from the parts sickle bar that I picked up at the flea market last weekend . I started taking the  parts bar apart  tonight the little square drive looks good hopefully everything else is in good shape as far as wear items
#10 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted May 24, 2013 - 06:17 AM
The biggest problem these use 2" knives, you can find them but they are hard to find and expensive. Some of the Gravely sickle used 2" knives, and so did Jari. I was able to find a NOS set of knives for mine and used JD guards to rebuild mine.
#11 CADplans OFFLINE
CADplans
  • 219 Thanks
  • 213 posts
Posted May 24, 2013 - 09:00 AM
I found an entire 7 foot brand new replacement bar with new sections that I could cut to fit mine.
After two years of poor cutting, I removed the guards and simply sharpened the ledger plates with a 4 1/2" angle grinder.
The machine cuts like a lawnmower now!!  :dancingbanana: Fine grass, tall stuff, it cuts it all.
My replacement sections were serrated, the ledger plates were also serrated.
Now the ledger plates are un-serrated after sharpening!!
Edited by CADplans, May 24, 2013 - 09:00 AM.
  • Alc and VSTROM803 have said thanks
#12 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted May 30, 2013 - 04:24 AM
Now that's a beast! I'd love to have one of those old Gravelys.
